Problems with743
/ Problems with743 #11
There is a removable lockout pin in the linkage somewhere close to the control valve. With the cab up, on the left side facing machine is the control valve. the top spool linkage is the front auxiliary, trace that back to its control you should find the lock pin. Some liek to put the lock pin back in when not using the front auxiliary so they don't accidentally lock the the aux. in detent which causes all kinds of problems.
/ Problems with743 #13
lol, all kinds of problems is right. Since the Aux hydraulics lines have never been used on my machine (indicated by severe rust and corrosion), they corroded right through. The right steering lever got bumped over to the right, detent, position and dumped out a bunch of hydraulic fluid on the jobsite before anyone noticed the leak. Quickly learned about that lock pin to prevent it from happening a second time while we finished that job.
Model of 1862 USS Genesee Ship in Acrylic Display (A59317)
Model of 1862 USS...
MMS MS36CS (A60463)
MMS MS36CS (A60463)
2000 Kubota KX61-2 (A60462)
2000 Kubota KX61-2...
2017 Ford Expedition SUV (A59231)
2017 Ford...
2007 Mercedes Benz -S550 AWD Sedan (A59231)
2007 Mercedes Benz...
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
