Brake switch
/ Brake switch #1
maxborden
Athens, Tx
M9540 Kubota
Do any of you know where the brake light switch is located on an M9540 Kubota? My stop lights are not working but tail lamps are. thanks
/ Brake switch #2
My m8540 has never had brake lights that work i bought it new in 2011 just assumed it does not have brake lights. If i find it does I'm going to have to track down the problem
Dave
/ Brake switch #3
My 9540 has never had any brake lights. I was surprised to say the least. It's open station, maybe the cab tractors have them?
/ Brake switch #4
It's weird....
I was looking through threads and saw this. My Case/IH has a brake light switch, but it's only for the cruise control to turn it off much like when you tap the brakes on your car. The tail lamps take a 1157 bulb, but seem to only use the weaker filament.
I took a look through the parts catalog for that tractor and didn't find a brake switch either.
/ Brake switch
Thank you everyone; Ill call dealer 2morrow. I'll post the answer I get.
/ Brake switch
I took my light assembly apart and it has three wires, ground, lamp, and brake. We'll know tomorrow!
/ Brake switch #7
Interesting. Is yours open station or cab?
/ Brake switch #9
Ours is a cab model and it has never had brake lights.
/ Brake switch
I called dealer this morning and there are no brake lights and no brake lights through the 7 pin implement connector. Atleast I know I am not crazy; I climbed all over the tractor and couldn't find a switch. I suppose mystery solved and have a good day!
/ Brake switch #11
That's what I figured all along. Kind of stupid!
If you're on the road like I am sometimes it would be nice for people to know you are slowing to turn in. It seems like if you've had the hazard lights on, then you switch to a turn signal, people completely ignore the change from both lights flashing to just one side flashing.
I wonder if the 60 series has them?
/ Brake switch #12
Well I can tell you that the Grand L 4240 and the 5740 cab models do have the brake light bulbs and wiring for the brake lights because while I was in under the dash I found a two cavity plug and joined the two wires together and the brake lights came on. The only thing that's missing was the brake light switch then I thought about it and realized I never touch my brake anyway because it's HST and maybe that's why Kubota never put the switch in.
/ Brake switch
The slow vehicle emblem and hazard flashers are for road. According to dealer, no tractors use them. I also found the wire terminals under the dash. The tractors are equipped with all essential wiring but no brake switch.
/ Brake switch #14
I call bull sh*t on the dealer. Maybe no Kubota tractors use them but there tractors that have brake lights.
/ Brake switch #15
If you use your brake then its worth doing. Its not hard to install a switch. Go for it.
/ Brake switch #17
I'm going to check to see if my open station has the wiring in place.
/ Brake switch #19
I'm betting it do. :thumbsup:
Well, the light is wired for the dual filament bulb but I can't find the other end of the wires.
Turn signal and running lights only.
/ Brake switch #20
If you ever find where they go update us on their location. It might be nice to rig up a brake switch
Dave
CAT 140M Motor Grader (A64047)
CAT 140M Motor...
Screen USA CF35D2 Tri Axle Towable Trommel Screen (A61572)
Screen USA CF35D2...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
(3) Fuel Tanks (A62183)
(3) Fuel Tanks...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
2000 International 3800 DT466E (A62180)
2000 International...
