Wide track tyre
/ Wide track tyre #1
Issues
Qld
Agrison 50hp
Swapped the two front tyres over & changed out the centre hubs on the rear.
Makes it feel so much more stable.:thumbsup:
/ Wide track tyre #2
- Agrison 50hp?
- Is that a locally disguised branding for Foton FT504?
- After the wheel swap, are the front and the rear wheels still in line with each other?
- Any concerns of a higher stress on the tractor, with the larger spacing between the wheel pairs?
/ Wide track tyre
I think it may be a BOMR make.
Yes the wheels are still in line.
No I don't have any concerns of higher stress.Giving it a wider footprint of about 150mm (6 inches) shouldn't be a concern.
I was more concerned of a roll over before.
/ Wide track tyre #4
- Agrison 50hp?
Lots of copies of the Foton's coming out of China trying to cash in on Foton's reputation.
Companies like BOMR and Luzhong even allow you to order a tractor with a "Foton" bonnet as an option hence you thinking it was a Foton.
/ Wide track tyre #5
I put the tires wide on my Jinma 284 about 8 years ago and over 750 hours, most of which is FEL work, and no ill effects. I make the tractor much more stable.
Chris
/ Wide track tyre #6
Chris
I'm going to go wide on my 304 too when I get a chance. The tractor seems somewhat narrow, and I know spreading the tires will make it solid as a rock.
/ Wide track tyre #8
Foton brand 4WD ute/pickup just went on sale in Aus, same company as the tractors I suppose. Website says that they use Cummins diesel motor
Foton Australia official website
Sorry for the off topic remark ...
Can you get rear duals for your tractor?, all the chinese machines seem to have very skinny tires
/ Wide track tyre
Skinny Tires? mmmmmmmmm
I just abandoned ship a couple of hours ago when the aforementioned skinny rear tire went airborn while carrying a concrete pipe rigged over the FEL.
Dropped the load which helped a little but still kept me in the air.Shut the engine down & put her in neutral,gently opened the upside door & jumped.
I had a large tree just in front of me so I knew there was no danger to anyone else,it hit that then all 4 were on the floor again so I unhooked & came in at a different angle.
Word of advice; If you have a 4 in 1 bucket,open it up & sling loads in close.
I've actually lifted rear tires before with loads in the bucket which prompted me to do the tire swap thing for stability.
/ Wide track tyre #10
Do you have a rear counterweight and fluid in those tires ..
I have seen pics of chinese DongFeng tractors with rear duals, mite be too much stress on your machine but it may be safest option
Keep it safe .. I enjoy your posts!
/ Wide track tyre #11
Dave have you got a counterweight hanging of the back of that thing?
Even with loaded tyres if your picking up a decent load you need a substantial counterweight of a few hundred kilo to operate safely and it helps take the strain off the front axles.
BTW how is that thing running now?
/ Wide track tyre #12
... and it helps take the strain off the front axles.
Beg to differ sir, with all due respect:
The front axle is the fulcrum point (as you know). Any counterweight added to the rear also adds that same amount to the front axle when lifting with the FEL.
/ Wide track tyre #13
That statement is just plain dumb. Are you forgetting that you have a set of rear tires and adding weight behind the rear acts as a fulcrum helping to remove weight from the front axle. Of course if you had the power in the FEL to pick up the rear axle with the counterweight on it, you would be adding weight to the front axle, BUT, FELs dont have that much power. Putting a couple thousand pounds on the 3 PH removes that much or more weight from the front axle (front fulcrum) by applying reverse pressure to the front axle. This keeps your rear on the ground and applies some of the FEL weight to the rear axle. The further back the counterweight is from the rear axle the more effective it is which is why a 1500 lb. bushhog on the rear does more than a 1500 lb. ballast box slung between the lift arms.
/ Wide track tyre
I took off the slasher when I did the clutch & haven't put it back on yet.Think I'll do that today before any more lifting.
New clutch install went well & seems to have done the trick so far but I think the fingers to the pto clutch are still a bit far away at max adjustment.Once I get my shed up & power to the block I'll machine up some spacers for the adjustment bolts.I'll post up some photos soon.
/ Wide track tyre #16
Great idea!!! I'll be doing that to my 50hp tomorrow, thanks for the images really helps. I have counter weights at the rear and filled them with water....works really well you might want to try it.
/ Wide track tyre
I filled the rear wheels with water to just up over 1/2 way & that helps too.
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2016 Ford F-150...
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A65053)
2016 CATERPILLAR...
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A64194)
2021 Mercedes-Benz...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A64557)
1999 22ft Sea Ray...
Car Hauler Trailer (A64556)
Car Hauler Trailer...
