No power steering on a Terramite
/ No power steering on a Terramite
the old grind, I too would be surprised if this system could not be retro fitted to something else. My draw to the machines has been the ease of access to working on things, and the fact that it uses a lot of non-proprietary parts. This steering box could be a real gotcha though. I'm wondering if my issue is not the box, rather the adapter plate that feeds the steering cylinder as ptgdigger mentioned. There was a similar thread on the Terramite forum where a guy posted that Terramite service recommended a new adapter plat as the cure to his loss of power steering. I am still hoping for an easier fix..
/ No power steering on a Terramite #22
ptgdigger you are correct in that this is how the Terramite system works, based upon the drawings and other threads. Will I get any useful information by teeing in a pressure gauge before the steering cylinder just to see where I am at?
That would be a good place to start, if you have good pressure and a reasonable amount of flow then that points the finger at something other than the trans.
However I suspect you will find very low flow at a very low pressure and confirm a trans problem. This machine can almost certainly be re-engineered to work off the auxiliary pump that powers the loader, the difficulty of that switch will be "what pressure was the steering system designed for?" vs "what pressure does the aux system operate at?" Someone will probably have to ask Terramite those 2 questions to know how to proceed from there.
Ray
I will cross my fingers it is not a trans issue. Apparently the adapter plate is bolted onto or into the trans. It is my understanding this adapter plate is replaceable without replacing the whole trans. Another poster said Terramite quoted $425 for the part. I wonder how much the whole darn trans costs...
Outside the box but, is it possible the hard steering is all in the steering box and is a mechanical binding issue and not a hydraulic issue at all? Tractor running or not, the wheel is hard to turn either way. When turning the wheel to the right with any speed I hear a clicking/ grinding noise either in the steering box or the trans.
/ No power steering on a Terramite #24
Outside the box but, is it possible the hard steering is all in the steering box and is a mechanical binding issue and not a hydraulic issue at all? .
Yes.......a pressure guage tee'd in either line going to the steering cyl may help to show if it is developing pressure, thus mechanical binding could be at fault
disconnecting hyd cyl completely while off the ground would be an option to detect mechanical binding, it should be free to turn
/ No power steering on a Terramite #25
I also have a 1993 T5C. My power steering does not work but I have noticed that it steers the same (hard) with the engine running or not. This tells me that my steering box is doing the work of moving the steering cylinder without the benefit of flow from the pump especially if the engine is not running.
Does your steering work at all with your engine not running?
I can steer with the engine running and not running, and it takes the same effort to steer both ways. I disconnected the cylinder from the front end to make sure the front end was not binding up some how. It was not. I am going to check some pressures to see if the hydrostatic trans is supplying pressure and flow to the steering box.
wdchyd, help me understand this. I have four lines coming off of the steering box. Two go to the steering cylinder. One goes to the hydrostatic trans. One goes to the hydraulic tank. So, I am assuming with the engine running the hydrostatic trans is constantly supplying flow to the steering box. When the wheel is turned either directon a valve inside the box directs flow to the subsequent side of the cylinder. When the wheel is not being turned, flow is diverted to the tank.
If this is true I would be best served to check for pressure coming off of the hydro trans before the steering box correct? Sorry, I'm green when it comes to hydraulics.
/ No power steering on a Terramite #28
Yes, you have it right (that's assuming that the hyd system is open center)
there will be flow going through the steering unit whether you are steering or not
Theoretically you could temporarily install a standard 4-way control valve and the thing should steer..(in/out & 2 cyl work ports)...you wouldn't want to leave it on there but it would show you if the cyl and pump were functioning ok
when i troubleshoot a hyd sys, I usually will start either at the source of the hyd power (pump) or at the end of the line (steering cylinder).....then work towards the middle
I will try to prove out what works and with a process of elimination will find the culprit usually fairly quick in simple systems......in hydraulics you'll find troubles will either be super simple or super major......always hope for the easy solution but don't be afraid to dig
I really appreciate all of the help and the free education! I hope to get some time to work on it next week. I will surely post my findings
I got a little time to check a few things out. I threw on a cheapie 3000 psi gauge and some npt fittings. I tee'd into one side of the steering cylinder, right before the cylinder. It showed maybe 50 psi... I then took out the gauge, and let the hose out of the cylinder to see how much flow I had visually. Engine running, turn the wheel to send fluid to disconnected hose, decent flow, a nice steady stream similar to the flow from a garden hose with no nozzle on it. Engine off, turned wheel same way, same amount of flow. I certainly would expect 500 plus psi to make quite the mess, and be much more impressive than this.
I then tried to tee right off of the hydro trans before the steering box, but I could not fit the tee in line. For grins I took that hose off and ran it at idle. Again a decent stream but not much pressure. I did not run above idle. So, I do not understand how the adapter plate works, but I was surprised to have flow. I was expecting nothing or next to nothing. I'm wondering if it is pumping but just barely and that is the whole issue. I would like to get the gauge tee'd in right from the trans, but will need a short length of hose. I wonder if it's worth it.
Why when I have the engine off does the turning of the steering wheel pump so much fluid through the lines? I am thinking as I turn the steering wheel either direction it is just working as a diverting valve for the pressure supplied by the trans. But this wouldn't explain why there is pressure with the engine off.
/ No power steering on a Terramite #31
cstamm81, I questioned the hose(s) earlier but still have some doubt, esp if you've fully inspected them. (auto PS experience..) If either had ballooned/blocked there should be some pressure in one direction or the other(?) but if your cylinder moves freely unloaded I doubt it would be too high without being connected (weighted?) or at the end of stroke. It actuates by flow, of course, but some resistance may(?) help you interpret the tests.
Is there any reason S-box pressure output wouldn't be the same with the engine running or not, since the cylinder would be doing the same work either way to turn the wheels??? Whether the box is working would then only be obvious by effort/feedback at the wheel. Either you're getting 'boost' or not. If we can be sure the adapter plate is supplying adequate flow/pressure it would seem to point to the box as the problem. (Oh man, .. do I hope not ...)
I'll have to reread whether this issue just popped up or the T-M came this way. Could moisture/rust have stuck something delicate inside the box's control valving while stored/parked and stiffening/locking-up something? I had water collecting in my column without a center-button on the s-wheel. (doh!) Call me lucky that it hadn't gone inside & froze.
I'm hoping I can help out here without being a pest about it, but IMO us T-M guys could use some team work to get a handle on our steering issues. btw: I hope TerramitConnecticut is tuning in by now. Not sure he's up & running yet ...
/ No power steering on a Terramite #32
internally in the steering unit there is a rotary valve and a geroler set (similar to a hyd motor).....when steering the geroler section acts like a manual pump with the rotary valve adding pressure to assist in the movement of hyd oil going to the steering cyl, this keeps the steering under you control and not oversteering acting proportional
when the engine is turned off then the geroler set is still "manually" pumping the hyd oil (without help from the hydrostat pump source), this condition is helpful when the engine goes into a stall you still have some steering......with the steering unit developing some steering flow this may confirm there is nothing wrong with the steering unit but rather the flow source (hydrostat)
internally in the hydrostat pump there is a geroler section on that rear cover that incorporates the extra pump for power steering....many times this section of pump is used for charge pressure for the traction loop (main piston pump to wheel motors).....they are probably using the same flow for both
if you're not getting proper flow/pressure out of that port then the next project would be to get the pump out and do some exploring
is there another pump mounted piggy-back on that main pump .....Pix..??
/ No power steering on a Terramite #33
Not speaking for cstamm81, but the 'Main power circuit' flow chart is shown on p 2.12 of the man. IIRC its one that was attached earlier but T-M's site abruptly went offline within the last wk or so & I'm digging for the PDF I printed mine from, a few computers/HDs ago.:confused: This popped up recently but doesn't explain a web shutdown, tho' it may portend an update/redo of the site ....New Terramite Owner Has Plans to Revive and Grow the Small Equipment Manufacturer
There is a gear pump at the tail end of things, but the flow chart shows it powering only the loader valve and digging/outrigger spool stack. Up front there's a 'backplate assy' (w/piston pump? ... it's between the HST and that 'adapter plate') that routes to the drive's torque-motor alone. There's a dedicated line shown from the HST to the s-box. At first look it appears the HST is getting its charge pressure independent of steering flow or any shared source/connection.
Many thanks to wdchyd for contributing his expertise. :thumbsup:
btw: I found/downloaded T5C's manual from here: http://www.terramite.co.za/T5CPartsManual.pdf It shows a bit of both steering setups vs my older copy but is mostly a parts guide. Mentally connecting the pages/pics leaves room for some confusion, but mebbe that's just me .... :mur:
/ No power steering on a Terramite #34
Yep, looks like they are using charge pressure to power the steering
/ No power steering on a Terramite #35
If you put your gage in a tee at the input to the steering valve, what pressure do you read?
Run the engine abut mid rpm, and you should get around 350 to 1000 psi, the steering.
The charge pressure on my pump is about 350 to about 450 psi.
That pump is very similar to my Eaton hydrostatic VSP pump, but my steering valve uses a separate pump for the pressure and it is about 3000 psi.
I am also thinking the pressure for the charge pump is stamped on the relief valve using a code. IE, 022 = 220 psi, etc
A flow and pressure test will will tell you more.
These are the fluids recommended for Eaton VSP pumps.
Specific types of fluid that meet these requirements are:
• Premium quality, industrial anti-wear type hydraulic fluid
• Engine crankcase oil — SAE 10w, SAE 20w-20, SAE 30
• Automatic transmission oil
• Hydraulic transmission oil
• Synthetic fire resistant fluid — Quintolubric, Cosmolubric, or equivalent
Note: If the natural color of the fluid has become black or milky it is possible that an overheating or water contamination problem exists.
Take level readings when fluid is cold.
Some people will look at this and say that is just wrong, but this if from the manufacturer. My VSP has been using motor oil since the90's.
I spoke to TM today. The guy was quick to point the finger at the adapter plate, which is sandwiched between the hydrostat and the rear gear pump. He said I should have between 200 and 300 psi at the adapter plate port. It sounds like this is something that has been known to fail. It does not look too hard to remove, and I wondering if it is repairable. He did have the plate in stock at a little over $400. Pricy but if this will make the power steering work without any jury rigging it is probably worth it.
I am still surprised I have decent flow from that port, but I am going to get a short length of hose and tee in the gauge just to verify pressure. I guess the pump section of that adapter plate just got weak? I may even run a line off the loader valve to the steering box and just crack the valve to make sure the system works at that point.
wdchyd, thanks again for the explanations to these things. the old grind, I appreciate the input it has also been a big help. I just found out my T5 is a 1994 model, what year is yours? There HAS got to be a replacement for that steering box of yours...
Well, I believe wdchyd was right all along. I've got a whopping 20-40 psi at full throttle coming right off of the adapter plate port. SO, that is definitely the issue. I also ran a line from the front loader into the power steering just to make sure, and when I cracked the valve the steering as boosted.
So, I definitely need the adapter plate. Would anyone have a decent idea if there is something in there that is rebuildable? I am assuming there is some type of pump, impeller, rotors? TM wants 400 for the plate, and 1400 for the plate AND the hydro trans, whole assembly minus the rear pump.
I barely ran this tractor before ripping into it, but I did recognize it did not have quite as much speed in forward as my other TM. There is also a growl from the trans when getting off of the hydrostat pedal. Lastly it seems to coast after getting off the pedal, where my other T5C immediately comes to a stop. I am bringing this all up wondering if this is a sign of a hydro trans on it's way out as well.
/ No power steering on a Terramite #39
Yea, the coasting is a sign the charge pressure is n/g (the same section that supplies pressure/flow to the steering)
Time to yank that pump, dissect it and post up close-up pix
the aux pump in the rear is not necessary to take apart, but it won't hurt to peek inside
I may have some used parts for that adapter plate.....I'll look 2moro at some used pumps kicking around.......you'd be into replacing the housing and geroler section if indeed the pump is worn
the rotation group (barrel, pistons and shoes) in the front section you'll wanna look real close at any wear......where the piston barrel rides on the valve plate you'll wanna look at that wear close too.....it may need lapping
pay attention to the cleanliness of the oil, sometimes contaminated oil will do this kind of damage without knowing it.....either way, you'll be doing a complete oil/filter change and rinse out the reservoir
So the replacement of the adapter plate should take care of the steering AND the coasting issue? Will this help with the speed in forward? The tractor seemed to have plenty of torque, as I loaded it up very steep ramps onto my trailer.
Are you suggesting yanking the whole assembly out; trans, adapter, gear pump in one? TM service told me 20 minute job to separate and replace just the adapter plate... maybe if you have done it before. Or, are the inspections you are suggesting just part of the adapter plate?
The other pieces you want me to inspect, is this going to be fairly straight forward or could I quickly have a nightmare on my hands? I am a pretty competent mechanic, rebuild engines etc but I do know I have my limits.
I would love to replace or repair everything, but spending around 2K (I am guessing) isn't really feeling great to me, on a tractor I only paid 3700 for. I hate to half a** things though, so if I could rebuild things while I am at this I am all for it.
As for the hydraulic system oil, previous owner just had it changed. Said he put in 10W-30, too bad as the manual calls for 15W-40 or straight 10W(?). Who knows what has been run through this thing it's entire life...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 Honda Crosstour Hatchback (A59231)
2012 Honda...
207274 (A52708)
207274 (A52708)
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
