backstop with FEL forks
/ backstop with FEL forks #1
mikehaugen
Elite Member
Lee, IL
John Deere 1070
the other fork thread prompted me to ask this. I have a set of forks from a forklift as well as the backstop, I do not however have the mounting plate for the forks. I have been looking to get one, and was under the impression that I had to find one that would be compatible with my backstop, but am now thinking maybe I don't care. Do you guys use a backstop with your forks? I guess maybe I don't need one, and would be nice to limit the weight. Maybe I should just forget about the backstop idea?
/ backstop with FEL forks #2
Like a roll bar or seat belt, it's not important till needed.
Be careful.
/ backstop with FEL forks #3
How would you attach it without one,, The reason I ask is I did it but they "the forks" attach to the ATI quick hitch...
/ backstop with FEL forks #4
yes use the back stop, UNLIKE a fork lift that stays basically flat/level , when a loader lifts many times, the forks tilt back and if carrying some items you may find them in your lap with out a back stop,, and a 1500 pound Bale or other load, mostly likely would be fatal.
The reason I ask this is because many people use bucket forks, and end up with less backstop than I would have with just the mounting plate (the back of the forks create about a 18" backstop). They don't seem to complain so I didn't know how much of an issue it was. The forks/backstop fare from a Linde (~5k) forklift, so it probably won't be that big of an issue to find the right mounting plate, I guess the weight was the bigger issue as the backstop probably weighs close to 100lbs.
/ backstop with FEL forks #6
Agree with the idea that you do not need a backstop until you need one. The hood on the small Kubota says I need one. A couple railroad ties or big logs can really crowd you when they come back at you -instead of dumping as you had planned.
/ backstop with FEL forks #8
This is the forks I made up over Christmas. The backstop is only 1 1/2" x 1/4" flat bar that I bent on the press and welded the pieces to the inside of the outer frame. This was then welded onto the fork assembly. For the cost of the flat bar I figure it will more than pay for itself the first time I need it. Also it doesn't impede the use of the forks or my vision when coming into a load.
/ backstop with FEL forks #9
That is very professional looking job. Looks easy to build, lightweight and very strong
/ backstop with FEL forks #10
Oh and I should of added this famous line to my post. Just ask me how I know. I was lifting a 15" thickness planner up to put it in the back of a pickup with my neighbours Mahindra tractor. We had it strapped down but the strap slipped and $3000 dollars latter my neighbour had a completely new front end on his tractor.
so, it seems that the consensus says that I should use the backstop. I can't argue with that, thanks for your insight/experience guys.
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
LOOK! (A63109)
LOOK! (A63109)
UNUSED JCT HYD TRENCHER (A62131)
UNUSED JCT HYD...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
