Backhoe Planting trees
/ Planting trees #1
1026R owner
Northern New Jersey
John Deere 1026R
I'm trying to decide the best strategy for planting trees and bushes. We have about five acres of grass and another 30 of wooded wetlands and I'm planning a lot of planting this spring (and in the years to come). I like the idea of a backhoe or possibly an auger to drill holes for planting trees and bushes. I also have some minor trenching I'd like to do to improve drainage. We have rocky, clay soil so digging by hand has proven difficult. However, I understand a backhoe on my John Deere 1 Series takes a lot of time to remove and reinstall when the mid-mount mower deck and other attachments are needed. Renting equipment might be the best option, but it means you can't always do what you want when you want to do it. Life is very good when we have problems like this to solve.
/ Planting trees #2
A post hole digger on a 3 point works great, dig twice as deep as your root ball, this loosens the soil and helps establish your roots. Be sure finished depth is level with the top of the root ball, backfill as needed. The excess soil can be used for a berm around the tree, for water.
Dave
/ Planting trees #3
How many trees are you going to plant? What size and kind are you planting? If you are planting bare root seedlings I would go with a dibble bar and do it in a two man team. This definitely depends on the number you have to do. I have tried to reforest my property (8 acres) and over the years this has been the best method for planting a couple hundred seedlings in a day or so.
/ Planting trees #4
/ Planting trees #5
Dave
I'm with Dave. I planted 65 3' saplings last spring with the post hole digger in sandy loam soil (no rocks like you may have) in 2 hours with two people. Works great.
/ Planting trees #6
My wife and I have planted thousands of trees in the past 28 years on our 30 acre property. If you are limited in your budget buying small 2 year bear root seedlings and planitng them with a dibble bar or simply cutting a v shaped hole with a shovel to place seedling in can get a lot planted. If you have the time to baby them by watering, feeding and weeding for the first years of their life you can have close to 100 percent survival. If you just pop them in and do nothing else the mortality will be higher but in my case it was overall acceptable with smoe species being very successful and others not so. Soil suitability was the biggest determining factor.
To plant bigger trees I've used a shovel then graduated to a back hoe and auger. Any of these do the job. The key is to make the hole bigger around and rather than deeper. If you dig the hole much deeper than the depth of the tap root of the tree you are asking for trouble as the disturbed soil settles the tree will sink deeper than it should be into the soil. That can be fatal. The nice thing about an auger is it breaks the soil up better than the backhoe. Use a larger diameter auger so you can use mix amendments like bone meal and compost or well rotted manure with the native soil to give the tree a nice wide bed for the roots to grow into. I use a tree auger to plant 6-8 foot fruit trees and cedars for hedges. The cool thing about a tree auger is it digs a "V" shaped hole which more natural to the shape of a trees root system.
/ Planting trees #7
Yes, I guess deciding what to buy is a good problem to have. I am biased towards a BH, and know a PHD will work especially the angled one botabill described would be great for trees. I assume you might be doing 3-6' size trees or small ones? If B&B trees then I would go BH.
I dig about 6" deeper and then backfill the hole with my composted leaves, then root-tone then water then plant the tree and backfill.
As with any property and planting, when you start ultimately things will grow and you will need to transplant and move trees and shrubs, thats best done with a BH, also getting in and out of your wet area a BH (tough to get unstuck with a PHD) and the BH with a mechanical thumb is a great logging/chainsaw assistant to name another.
On average I transplant 10 shrubs a year, also great for digging existing FREE trees in forest (small 1-2" dia) up in one scoop and moving / reforesting other areas.
/ Planting trees #8
No doubt the backhoe is the most versatile option all round for digging and planting bigger trees/shrubs. A little hint I was given is to skim the sod off the surface where the hole is to be dug then place it in the bottom of the hole, green side down, where the tree is to be planted. Just tried it this year but it seems to make sense. That would move some nutrition down to the root zone and kill the surface competition.
/ Planting trees
Great stuff! Thanks for all the feedback!
I should have mentioned size and number of trees: I want to plant maybe 10 ball and burlap trees about six feet tall. American Hornbeam, Serviceberry, Weeping Willow, Norway Spruce, Winterberry, maybe a Hazelnut, perhaps some maple, a few fruit trees (apple, peach). Plus a few dozen bushes including blueberry, raspberry, blackberry, viburnum (cranberry bush). Will plant some bare root trees (already have), but it's a new property and don't always have the patience to wait for them.
Sounds like a backhoe would be a great thing to have. I really think it would be helpful in planting and transplanting, and very helpful for trenching for drainage in several places on my boggy land. But my understanding from an excellent and practical-minded John Deere technician is that it is very difficult and time-consuming to take the backhoe off the tractor or to reinstall. It has a subframe that attaches to the tractor that is apparently quite involved to mess with. Can't really justify multiple tractors. An auger should work well for tree-planting, and would be much easier to remove and reinstall. Don't know what a PHD is. (I only have a bachelor's -- and I'm not the sharpest tool in the shed, neither!) I did not know about clamp-on bucket spades and will look at that. Nor did I know about a dibble bar, which looks like my bulb planters. I frequently wish I could draw on a two-man team, but it's just me here, and I've found it's hard to hire simple laborers.
/ Planting trees #10
Much of my experience is similiar to previous posters. But my approach was to start with what I called my "tree bed" which was a dedicated area where seedlings were planted (several hundred from the State Extension). As the they grew I picked the variety (Cedar, Austrian, White and Scotch pine) and the vigorous ones and transplanted them when about 2-3 feet high.
The tree bed allowed cultivation and water to be most convenient. Of course, once they were transplanted that became more time consuming but the survival rate was over 90%. This was done with shovels, hoes and a wheelbarrow. Oh, did I mention 4 teenagers ?:D Also, somewhere I recall that the sod should not be placed in the hole because the decomposition causes gas to form that is harmful to the tender roots. Maybe that's an old misconception.
.....also forgot to mention the 8 HP walk behind rototiller that was quite helpful in this and many other garden projects.
/ Planting trees #11
1026
PHD = Post Hole Digger and as botabill mentioned you should get different augers - 4" - 8" and then a V shaped for digging holes for B&B trees.
Just another point on a backhoe, most of the time to remove and reinstall is the alignment process, and many here make a frame with something like furniture dollies and wood or metal with casters. This makes the process much easier, also rolls away for storage - of course this only works well if you have concrete or a hard surface area where store your equipment.
/ Planting trees #12
my general rule i always grew up with was a hole twice the size as the rootball. so figure a 18" root ball... 3' diam hole about 18" deep. I can dig one of those in IL ground in about 3 min with a hand shovel.
so by the time you order some attachment and spend $$$ on it.. you could have just hand dug the holes with a good shovel and enjoyed the rest of the time sitting in the shade admireing your newly planted trees
/ Planting trees #13
Depends on how many trees you have to plant and what size trees... I have planted thousands with a dibble bar, but you are limited to roots about 10" long with most of them... mostly small 1-2 year old trees. If you are talking bigger trees, takes awhile to properly plant them depending on how long the roots are, and if you want to spread them out properly. If you have acres that you want to plant that is cleared, you can hire someone to come in with a planter and put them in... Plug seedling are quick to plant and are a good choice if you can get a deal on them... Trouble with planting trees is you have to get them in the ground.... and if you are talking thousands of little ones... or hundreds of big ones.... you are looking at a lot of work... but good work... :) Here in Michigan you can buy trees from most of the County Conservation Districts fairly cheap in the spring and fall...
/ Planting trees #14
My in-laws live in IL and it is unbelievable how much easier it is to dig a hole there. To dig that same 3' diameter by 18" deep hole here in SW PA it would take me at least an hour and would have a sore back from using the digging bar. Also found out from my in-laws that they had never heard of a digging bar since they don't need one, well unfortunately you don't dig by hand in PA without one.
I use a backhoe attachment on my 5240 to plant trees and it works very well. To remove or install takes about 10 minutes, if that long. The subframe stays permanently attached on a Kubota, so you have two pins and the hydraulics to remove/install.
/ Planting trees #15
wmonroe,
Indeed, digging is a regional challenge.
Most (small/med) backhoe owners on TBN are not in the midwest or south, but in the northeast/east and west/northwest.
This is due to the glacial till left behind from the hills.
Carl
/ Planting trees
I agree grabbing a shovel is often a good plan -- but not here! Here in northernmost Jersey there is heavy clay soil. And there are these hard things called rocks. Ain't diggin' no tree hole here in 3 minutes. 'least, I ain't. When planting bulbs, my bulb auger goes down six inches, hits rock, and that's it. Those four teenagers is what I really need: Slave labor! Wish I had them. When I was a youngster I did this kind of work. Don't see many kids doing that now. Professional hired help has proven to be very, very expensive. A landscaper lives across the road, he has crews and he's good, but it costs a bloody fortune. I'm always bowled over when I get the bill. And no one does things zackly how I want them done. Rented equipment is inconvenient because I see a tree I want, bring it home or have it delivered or order it, and it needs to be planted then.
Sounds like the auger with a selection of screws is the best plan, or I learn how to swap out a backhoe in less than a half-day's time. Sounds like the Kubota backhoe is a lot easier to swap than the one on my Deere 1 Series.
/ Planting trees #17
/ Planting trees
1026R
I have looked at the videos and instructions on the BH removal and install - its really pretty basic and easy maybe 5-10 minutes most.
Removing and Storing Backhoe
John Deere Front Loader and Backhoe Attachment Demonstration - YouTube
This seems very simple and easy - pretty much the same for the Kubota machines - I wouldnt be concerned. I wonder why the mechanic said it was tough?
Carl
You're right, Carl. That looks pretty easy, and quick. Thanks so much for showing me this video and the instructions. Their field guy seemed to be under the impression you had to remove the subframe to attach the deck mower. But the deck mower was on that tractor plain as day. He works on a lot of different equipment so maybe he was thinking of some of the bigger models. If it's as easy as it looks here, I'm thinking I need to order me up one of them backhoes this spring. Removing and reinstalling the front loader couldn't be easier, and switching around attachments to the three-point hitch is really easy. The mower deck is the most cantankerous but it works well most of the time.
/ Planting trees #19
I think it's time for a trip to the dealer and test out one with a BH installed. This would give you first hand experience with your model or similar. I would imagine a BH purchased and installed after the fact may be a bit spendy tho.
All I can say is the BH is worth every penny when you have rocks, roots, and very little topsoil like here on the NH coast - we have the glacial till - 3-5' rocks and plenty of small ones too.
/ Planting trees
I'm sold!
Just got in from snow-blowing the driveway. Love that little tractor!
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
Agline ADM109 Disc Mower (A64047)
Agline ADM109 Disc...
2024 Case TV620B High Flow Forestry Compact Track Loader Skid Steer (A61567)
2024 Case TV620B...
2023 Mac Trailers 48ft. T/A Walking Floor Trailer (A61568)
2023 Mac Trailers...
New/Unused Quick Attach Flail Mower (A61166)
New/Unused Quick...
New/Unused 1in ALR Impact Wrench (A61166)
New/Unused 1in ALR...
