Positive ground on ym2000?
/ Positive ground on ym2000? #1
dgizmo1
Leoma, TN
John deere 318, ym2000
Just picked up my new toy a YM 2000. Left the key on last night and of course battery died. Was jumping off today when i realized it had a positive ground. It starts and runs fine, but i thought these had a neg ground. None of the lights work on it, can somebody tell me if this is right. By the way it is one of the red ones
/ Positive ground on ym2000? #2
This should help.
Thanks for the quick response, but already found that diagram, but still does not give polarity of battery
Thanks again for the quick response, but doesn't that mean it is cranking backwards? So if it is cranking backwards due to polarity being backwards that means it should be running backwards. Now i could be wrong (and won't be the first time) but as far as i know a 4 cycle engine can not ryn backwards
/ Positive ground on ym2000? #6
No, it can't run backward. For one thing the fuel injection is ~ 20 degrees before the piston gets to the top, so 40 degrees later than that would run terrible if you could start it at all.
Could the battery have been charged backward? I think that is possible.
Have you used a meter to verify the labelling on the battery?
As for your bulbs- Oil and Charge should light with key on and engine off. Temp can only be tested by lifting the wire off the sensor up front, and sticking a grounded wire into that wire's connector.
/ Positive ground on ym2000? #7
Yes it is possible to have a reverse polarity battery, the lights still should work either way. if it is indeed backwards the regulator will be stuffed. a multimeter will confirm this.
/ Positive ground on ym2000? #8
Yes it is possible, if fully discharged till it seems completely dead a reverse charge can be done but apparently it takes a hefty charger to get it started. i have never tried it myself but a friend has and it works.
/ Positive ground on ym2000? #9
Yes a battery can be re-charged backwards once it has been completely drained of any power just as California and Neat has mentioned, Back this summer I purchased a used but supposedly " reconditioned battery " once I got it home and installed into my Roper tractor and one turn of the switch would sent the starter spinning but would not throw into the flywheel, When shorting the solenoid in attempt to start it only result in blowing the fuse,
I then hooked up my charger / Jumper to try and get stronger current and sparks flew as though I had wrongly connect the jumper.... I then brought the issue here to the YM of TBN explaining what has happened and was also suggest to check the battery polarity, It turned out to be Black was Pos+ and Red was Neg-, I connect the battery this way and resolved the issue, But rather than trying to drain the battery again and recharge it the correct way, I simply shaved off the protruding + & - and changed markings by carving them back into the right side so not to be confused again, ......... As far as I know any connection from a ( Grounded side ) of a battery to the chassis/ metal frame would be considered a negative ground, Not sure I know what a Positive ground is. Positive contact Yes! Positive ground No! :confused:
/ Positive ground on ym2000? #10
This Positive ground talk had me curious, so I looked it up on Google, and found that yes there was a positive ground system
used on the Old 6-volt systems,.. in fact a positive ground systems has been dated to back in the 1920's..... which explains why I never heard of it:cool: I ain't that old:D
/ Positive ground on ym2000? #11
Positive ground was common on British cars and some American brands. Maybe early Ford? I think it was considered technically superior because while a spark plug can have only one center, insulated electrode that erodes rapidly, a Positive Ground system can use spark plugs that erode multiple side electrodes instead of the center one. So they last longer before the spark gap is too great. Ok that's something I was told 50 years ago. Anybody have better information?
I know that alot of the older tractors and cars did have a pos ground on it was the reason I was asking. I am thinking the old 2n for tractor had pos ground. Found out why it was hooked up with pos ground, the battery had to be placed with terminals to the front of the tractor and the cable was not long enough to reach, so they hooked up how they could get it to hook up. But the unusual thing is it appears that the starter does not care what you use for ground, it spins the same direction either way. I think the lights do not work because I found the fuse block and all fuses are blown. I gave 1400 for it with no equipment so I hope I did not get burnt, but I have to still fix the left brake, left wheel seal, diff lock, and grease the front bearings and tighten (they are loose, but not binding). I know I have read that people say these little yanmars knock hard, but to me is sounds like a lawn mower. but of course i also need a new muffler it is half rotted. Thanks to everbody for the great information and all of the help
Was fixin to take lift cover off to take a look to see what wad going on witn thanks for the info it gives me something else to look at
/ Positive ground on ym2000? #15
quite common on older tractors.. vw bugs.. etc.. ;)
just not real common on newer machines...
/ Positive ground on ym2000? #16
i believe thermionic emission will be a good reason given for positive ground.
( edison effect )
soundguy
/ Positive ground on ym2000? #17
I've had my Yanmar 2000 since around 2000, and have put about 3 batteries in it, have never seen or used the positive ground, just put a new ground wire for the battery to the frame. 12 volt system, negative ground.
/ Positive ground on ym2000? #18
wow.. that's alot of batteries in 12 years...
that is alot of batteries, the one I am recharging is from 2009 and would still start it strong till I left the key on.
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
2025 Wolverine ADB-13-1218R Hydraulic Auger Set Attachment (A66734)
2025 Wolverine...
2012 INTERNATIONAL PROSTAR+ 122 6X4 ROAD TRACTOR (A65054)
2012 INTERNATIONAL...
2012 Honda Crosstour Hatchback (A66738)
2012 Honda...
Welcome to the Ranch Metal Decorative Sign (A64557)
Welcome to the...
FIXED FIFTH WHEEL ATTACHMENT (A67714)
FIXED FIFTH WHEEL...
