Comparison Cordless impact wrenches
/ Cordless impact wrenches #21
/ Cordless impact wrenches #22
I don't think so but I'll look in to it. If so, it would surprise me
I did a quick search and did not find anything, it is at least US made. I know they make their own air tools.
/ Cordless impact wrenches #23
I have the dewalt 18v cordless impact.. love it, I use it more now than I do my regular 18v drill.. any time I need to drive a screw that is. when I bought the drill it came with 3 batteries so when I bought the impact wrench I got it just tool no batteries. 22
/ Cordless impact wrenches #25
I like others kinda was trapped into Dewalt. If I had a choice ,Milwaukee would be in my box, that being said I have 2 1/4" impact drivers, a 3/8 impact ( which will shear a 3/8 grade 5) and a 1/2 impact( which has about 300lbs torque) the compressor and big impacts only come out for the tough stuff !!
/ Cordless impact wrenches #30
I'm curious, why the attitude? I stated that I wasn't sure from the beginning, and asked if you did.
I give the same that I get.{Well, then who makes it, or do you know?} The proper way is, or don't you know!!
/ Cordless impact wrenches #32
souix also makes a lot of their air tools. Their drills (which are outstanding) are souix, and their die grinders may be as well. I haven't figured out their impacts yet, I think they may be CP, but not sure.
as others have stated, for price I would go with dewalt, especially because you have batteries that will work on other things. I have yet to be disappointed with anything dewalt. If you have the money, check out the snap-on. The ingersolls look interesting as well, and I would look into those if I didn't care about battery compatibility.
/ Cordless impact wrenches #33
If they own Souix then they kind of make their own.
/ Cordless impact wrenches #35
not to start a debate here, as it is not relevant to the topic, but Ford Motor Company used to own Volvo, does that mean a Volvo s80 is made by Ford? I know some people consider it the same thing, I don't though. Many companies own other companies but have no bearing on the manufacturing process, especially in the tool world. Check out Apex Tool Group, lots of companies under the same parent company- though very different tools at very different degrees of quality. Just my opinion... yours' may differ.
/ Cordless impact wrenches #36
I have 4 Milwaukees.
1/4" Hex & square grive
3/8" square drive
1/2" Square drive.
All are the newer 18 volt Lithium Ion
The 1/2" is 450 ft/lbs.
I think that is under rated / what a work horse.
I too have been using it more than my composite 1/2" IR2131
Just wish it had a variable torque setting.
It is so darn easy to over torque bolt with it at first.
I am going to invest in some pre-set torque sockets.
Accutorq (ACC10-0322) 10 Piece Lug Nut Torque Socket Set - Amazon.com
Check CPO milwaukee for great deals
http://www.cpomilwaukee.com/milwauk...e-m18-impact-drivers-wrenches,default,sc.html
CPO has other web sites like Metabo, Skill, Bosch, Dewalt
http://www.cpooutlets.com/
I have bought mfg refurbished and they work and look like new.
/ Cordless impact wrenches #37
3/8" square drive
1/2" Square drive.
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=294628"/>
I recommend buying a quality torque wrench (snap on) instead of torque sticks, they are not that accurate.
/ Cordless impact wrenches #38
I have always wondered how these work, it is usually not very clear. Are they simply made to different "springyness" and absorb impacts past a certain point, or what? Also, how inaccurate are they? For things like wheels, wouldn't +/- 10% be acceptable, or are they worse than that?
/ Cordless impact wrenches #39
I have 2 snap-on torque wrenchs 1/2"
Also a 3/8"
OTC 1/4"
I just like to spin bolts/nuts up quick close to torque with a gun and final hand torque always.
The Milwaukee is so darn fast and powerful I have shot past the spec. needed.
I have learned to be quicker with the trigger and short bursts.
With the air gun I would just turn the regulator down
There is no adjustment with the milwaukee, but the portability is great.
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
Bush Hog 3715 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Bush Hog 3715...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2012 Caterpillar 302.5C Mini Excavator (A61572)
2012 Caterpillar...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
iDrive TDS-2010H...
