John Deere 4410 not moving when peddles pressed
   / John Deere 4410 not moving when peddles pressed #11
Look at the indicator on the rt fender, there will be a series of long and short flashes. Write them down. Let it go through the series a few times to make sure you got the right and post them. Then we will know where to tell you to look. If you want to do a visual inspection, look under the tractor on the right side to see if some brush pulled out the wires to the pedal potentiometers.
Is there a site glass or dip stick to see if the transmission oil is at the proper level.
   / John Deere 4410 not moving when peddles pressed #13
2012 KENWORTH T800 DAYCAB (INOPERABLE) (A50854)
2012 KENWORTH T800...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
CATERPILLAR 740B OFF ROAD DUMP TRUCK (A51242)
CATERPILLAR 740B...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
