TS CountyLine PHD help needed
/ TS CountyLine PHD help needed #1
pokerboy57
John Deere 3320
Folks
I just purchase a 3PH CountyLine PHD from Tractor Supply. This is the URL to the product CountyLine® Post Hole Digger - 2100220 | Tractor Supply Company
Unfortuatel the product manual and assorted nuts & bolts were not included (missing). If some one has this item I have a couple of questions
1. Does the product use a bolt to connect the bell to the pipe that holds the gear box ?
2. What should I use (shear bolt ? ) to attach the auger to the gear box ? It looks like 2 bolts should be used there instead of one ?
The rest looks pretty straight forward to me. I cannot find the owners manual online If anyone knows where that is located I would sure appreciate the location
/ TS CountyLine PHD help needed #2
What you have there is a PHD manufactured by SpeeCo. You can go to their website and bring up the page for the PHD's and and they have a "download manual" button on the pictures of the PHD's. Hope this helps, let us knowl
Tom
:thumbsup:
/ TS CountyLine PHD help needed #3
Tom
:thumbsup:
IMO great advise from Tom also this will help :Tractor and Skid Steer Attachment Videos
Play safe check your gearbox oil those thing come shipped dry !
Boone
Actually I went back to the store and we opend another in the manual cylinder was the manual and a bag of hardware.
/ TS CountyLine PHD help needed #5
Hi,
This is my first post and I have been tractoring on my 2 acres for about 2 years now. I bought a TS Countyline Model 100 PHD 2 years ago and have dug maybe 100 holes for fence, retaining walls, nothing to write home about. Well something strange happened recently. I had hung up the PHD on a PI-shaped post and 2x10 brace for chains and 3-pt implements about 6 months ago, and the minute I took it down and hooked it up it began fast-leaking oil from the gear box shaft that hooks up to the PTO driveline. Wow. Had to be a bum "memory" in the seal vinyl where it got a smile that would not snap back and return snug to where it was supposed to be. Tractor Supply people agreed. One of them, a customer-oriented young man said he knew someone at the Countyline Division. He called his contact, had me fill out a form for my 2 years used up on the 3-year warranty and called his friend back and gave him the essential information. Had to be a vinyl seal gone all wonky-jawed from too much pressure from the wrong way. He would send the TS branch a repair kit for the PHD. So when I was called to come pick up the repair kit which was to include new seals, bearings, gaskets, and etc. and guess what? I could hardly lift the cardboard box. Inside, packed in a square wooden box was a new GEARBOX! Can you believe it? Talk about overkill. Driving thumbtacks with a sledge hammer. But I ain't griping. I just went all slack-jawed when I saw such service and complete caring about the cutomer. TS, I salute you. Maybe they thought I couldn't replace a seal. Or maybe they just wanted to be on the safe side. But one thing is certain: TS was on the customer's side. And the young man who helped me, his customer, knew what he was doing. I have always been a fan, but now I am devoted and dedicated to buying stuff from them. You think maybe Kubota might send me a new tractor if I complain that the FEL won't sculpt a dirt surface like cake frosting because it is higher on one side and cuts a llitte ditch on the other? :laughing: Just kidding. EMERYBOARD
/ TS CountyLine PHD help needed #6
Some guy wrote about buying an extended warranty on his bicycle at one of the chain stores. If I remember correctly, he complained that the bearing in the peddle went bad. They sent him a whole new bicycle.
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2012 INTERNATIONAL PROSTAR+ (A60736)
2012 INTERNATIONAL...
2016 PETERBILT 579 (A60736)
2016 PETERBILT 579...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2013 Nissan Altima Sedan (A61569)
2013 Nissan Altima...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
