MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,697
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
YES!
My JD 6415 has the deluxe rear SCVs. HUSCO 301 Series.
There is a black knob with three positions on each valve. One is for spring return to center and has float, another is with detents at each position ( extend/retract) and when the hydraulics gets to full pressure it springs back to neutral (usually when the cylinder is at end of stroke or fully retracted). It also has position where the lever will detent in either extend or retract and stay until moved. This position also has float. For a hydraulic motor you use this position starting with the valve in float and then moving it to retract to run the motor. Move back to float to stop the motor.
There is a second knob to control the flow.
The valves also has internal load checks.
I saw that and thought that I posted that I had seen that in my second follow up post. :confused3: But I guess that I was not clear, so thanks for following that up and confirming.
