mf 1020 hyd problems
/ mf 1020 hyd problems #1
stonestacker
auburn ca
1020 diesel 4wd-1936 RD4 CATTERPILLER-1948 FARMALL CUB
Hey guys
I have a mf 1020 diesel 4wd, it has been sitting for a few years, it had water in the fuel so i drained it, put
fresh fuel drained bowl bled out old fuel it is running now, but the hydraulics do not work (FRONT OR BACK) SO
I checked the fluid and it was low so added fluid, still nothing, is it possible there is air in the lines and pump and
if so how do i bleed it? thanks for any help Bill:confused:
/ mf 1020 hyd problems #2
Hey guys
I do not think there is a specific bleeding procedure other than lowering and raising the 3pt repeatedly. You could try changing the fluid and filters since the filters could be part of the problem. You may have a bad pump too. I posted the procedure for changing it in an earlier post, so if you need the details, do a search. Mine is a 1010 but I think they are similar. You just may have more filters to change if you have hydro drive.
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2022 Chevrolet...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
Giyi Mini Excavator Attachment Set (A64912)
Giyi Mini...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
CATERPILLAR WHEEL LOADER (A65053)
CATERPILLAR WHEEL...
