Tires Woke up to this today
/ Woke up to this today
I may try the ratchet strap around the circumference first. Usually works well.
/ Woke up to this today #24
There is no need for the starting fluid explosion or the strap. Those are for tubeless tires, he has a tube.
/ Woke up to this today #25
I've always wondered, why are there four bolts and two lug nuts? I can see why the studs help you locate the wheel, but why not use all studs and ditch the bolts?
I wonder if the studs are used to attach the tractor to the steel shipping crate. Two of my rigs have the studs - much easier to install the wheels - especially if loaded.
/ Woke up to this today #26
No, they do not use the studs to attach the tractor to the crate. The studs are installed by the dealer. Trust me I assembled many of them.
/ Woke up to this today #27
Yes, great observation, forgot about that.
/ Woke up to this today #28
2 reasons for bolts instead of all studs.
1. cost - it costs more to make stud & nut for it than just a bolt. May not seam like much but multiply it by several thousand tractors built it adds up.
Seems backwards. A bolt is a more complicated part to machine than threaded rods or bolts.
/ Woke up to this today #30
If you have ever took off a tractor tire, you would know what the bolts are there for. You just hang the rim on one of the studs and roll it till the other bolt slips in then tighten the nuts. Then all the stud holes are aligned and easily start. Imagine trying to manhandle a loaded tire just perfectly to align the holes and then trying to get a stud bolt started.
/ Woke up to this today #32
Be glad you didnt have beet pulp in the tire.... it would have looked like a crime scene.
I had a tire blow in my lean to years ago. the tire had calcium chloride in it, and the stuff destroyed 3 sheets of 16 gage (4'x8' sheets) steel that i had stored there. the sheets were rusted disaster within 24 hours of the burst tire.
This'll sound kinda corny, but what does the manual say? My old Kubota manual listed pressures, as does my current NH manual(12-14psi R1 13.6-24)
I don't have the manual, it's an old machine. Thanks.
Edit:
The tires that are on it now are also a different size from the ones that came on it according to TractorData. Who knows what people have done to the old girl over the years!
/ Woke up to this today #35
That makes it more of a challenge for sure.
Edit:
/ Woke up to this today #36
[QUOTE="Spikes;]
Edit:
The tires that are on it now are also a different size from the ones that came on it according to TractorData. Who knows what people have done to the old girl over the years![/QUOTE]
There was more than one tire option. We almost never sold a tractor with the standard tire, we sold them with the oversized tires most of the time.
Very cool information. The 4x4 still seems to work flawlessly so maybe the tires are stock size (although they were new upon delivery to me).
/ Woke up to this today #38
There was usually the standard Ag tire (R-1), at least one turf tire, then an oversized Ag tire (R-1), and by the time of your machine there was an industrial tire (R-4) option too.
/ Woke up to this today #39
DING! DING! DING!
We have a winner!
/ Woke up to this today #40
I have never got a flat. :D tractor.jpg
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59911)
2004 VOLVO VHD...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
John Deere Rear Rim (A64119)
John Deere Rear...
2023 Deere 325G (A60462)
2023 Deere 325G...
