It's only flat on the bottom !
I've always wondered, why are there four bolts and two lug nuts? I can see why the studs help you locate the wheel, but why not use all studs and ditch the bolts?
2 reasons for bolts instead of all studs.I've always wondered, why are there four bolts and two lug nuts? I can see why the studs help you locate the wheel, but why not use all studs and ditch the bolts?
You may have trouble getting the tire to seat in the bead. You can spray a LITTLE starting fluid between the tire and rim then hold a flame near it, that will cause a small explosion that will force the bead to seat. I use one of those lighters with the long snout on it so you don't have to get your hand too close.
