Tires Woke up to this today
/ Woke up to this today #1
Spikes
Rogers, Ar.
Kubota L3450
Bummer.
/ Woke up to this today #2
Ouch.
Ever used tire plugs? (Or is there a tube in there?) On tubeless, the plugs work well.
/ Woke up to this today #3
It's only flat on the bottom !
It's a tube tire unfortunately. I wish my wife would make me sleep in the garage ( with the Harley )!
Kitty said he would be happy to help me.
/ Woke up to this today #10
I've always wondered, why are there four bolts and two lug nuts? I can see why the studs help you locate the wheel, but why not use all studs and ditch the bolts?
I have no idea on this. Doesn't even seem like it would be a cost saver.
Anyone have any advise on getting the tube out of the tire? I have had good luck with tube patches in the past so I think I'll try that.
/ Woke up to this today #13
2 reasons for bolts instead of all studs.
1. cost - it costs more to make stud & nut for it than just a bolt. May not seam like much but multiply it by several thousand tractors built it adds up.
2. studs are on there for conveniecne of installation. - more so to reduce factory assembly time than for our (customer) convenience. In production, time is money.
That looks safe, right!
Ready to drive the truck onto tire to break bead.
No suggested pressure on the tire. Any ideas? It's a 13.6-24.
It's going down about .5 Lbs every 15 minutes. Time for a tube patch.
That should do it.
Tore the valve stem taking the tube out. Done for now until I get to Tractor Supply for a new one later.
/ Woke up to this today #19
You may have trouble getting the tire to seat in the bead. You can spray a LITTLE starting fluid between the tire and rim then hold a flame near it, that will cause a small explosion that will force the bead to seat. I use one of those lighters with the long snout on it so you don't have to get your hand too close.
/ Woke up to this today #20
Many Youtube examples of this if you want to watch somebody else do it. Good luck not blowing yourself up! :eek:
2025 Swict 78in Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2011 John Deere 9770 (A64119)
2011 John Deere...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2018 Kia Soul SUV (A61574)
2018 Kia Soul SUV...
2012 Chevrolet Silverado 1500 Pickup Truck (A61573)
2012 Chevrolet...
