New Grapple exceeds expectations
   / New Grapple exceeds expectations #31
Nice looking grapple! :thumbsup:
   / New Grapple exceeds expectations #32
While being worried about weight can be a issue, whith the bigger tractors like KY's it really is not a big thing. His is rated at 2700 but that is at full lift, it is more in the 3k to 3500 at the ground I would bet. At least I Know it is with mine. The only time I have any issue is with big stumps. I am happy with the 48" one that I have for digging out trees, it puts less stress on the loader arms. Dug out a 24" maple the other day, worked pretty good. CJ
I can see where sometimes a smaller grapple could come in handy. Especially concentrating more force into a smaller area.
   / New Grapple exceeds expectations #34
That is a nice width grapple for brush and debris and general purpose. The 800lb weight is not an issue at all when handling brush on that tractor. I like how long the lower tines are, very nice for digging out brush roots. The only possible issue could be on heavy roots but that is where another style/size might work well.
So far the weight is no problem and the width is fine.
   / New Grapple exceeds expectations #36
Wow! That sure looks it is working good for you. I like the picture of the rock, I would be too chicken to try and do that. LOL
   / New Grapple exceeds expectations #37
I want your grapple.
It would look perfect on my L45.
ac
Thanks Guys, it sure makes things a lot easier.
   / New Grapple exceeds expectations #40
I just received my new Anbo GRS 72 Grapple last Thursday and took it to the farm to clean up some trees to make bush hogging a little easier. I must say it's built like a tank. Ran into a solid rock that practically stalled my L45. I got off real quick expecting to see several bent tines and to my amazement there was hardly a scratch. Moved a lot of downed trees, uprooted several and even found a new use trimming some pine trees that had grown close together making it impossible to mow between. Spent around 2 and a half days total. Like many of TBN grapple users, I love my new Grapple!!!View attachment 292037View attachment 292038View attachment 292040View attachment 292041
Kytractor
I have been looking at grapples for a bit. Following your thread it seems like you have a really nice one. I talked to an individual at ANRO today and he told me that he recommended the same one you got which is what I had previously decided was the correct size but wanted independent input from the folks that build them. (The guy actually grew up very close to where I am at and knows the local dealers from when he lived here.)
My question to you is: What other grapples did you look at and what was your decision process that got you to the model that you bought? There are obviously less expensive grapples available but you decided that it was worth the money to get the GR-S. Why?
Thanks
HYD 4N1 PIN ON COMBO BUCKET (A51243)
HYD 4N1 PIN ON...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2014 Jeep Cherokee Sport SUV (A50324)
2014 Jeep Cherokee...
2014 International Pro Star Semi (A50514)
2014 International...
2014 CATERPILLAR CB54 XW SMOOTH DBL DRUM ROLLER (A51242)
2014 CATERPILLAR...
