3pt arms problem descending
/ 3pt arms problem descending #1
tiehacker
Jefferson City MO
John Deere 2305
I have JD 2305, The 3 point arms go up well but are very finicky going down, sometimes they just won't go down, even if I'm standing on the drawbar, sometimes they work ok. When it is not working well, I adjust the flow control valve, if its all the way open it won't allow downward movement, if I crank it in a little it will go down very very slow.........Any ideas???
/ 3pt arms problem descending #2
:welcome:
/ 3pt arms problem descending #3
May have to remove it and blow it out.
3 pt arms are working now. Like Murphy1244 said, blow it out. The flow control valve was sticking, probably from lack of use,
UNUSED WOLVERINE HYD AUGER ADB-13-1218R (A64281)
UNUSED WOLVERINE...
10in Digging Tooth Bucket Excavator Attachment (A64194)
10in Digging Tooth...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2013 TIGERCAT 720E FELLER BUNCHER (A64276)
2013 TIGERCAT 720E...
