Need advice!
/ Need advice! #1
maximus1277
Manchester CT
2010 KUBOTA B2320, 2010 KIOTI CK27, Kubota L3940,JD110 TLB
Ok... Need serious advice. I'm about to make a great deal or a big mistake. I found a 2010 kioti ck27 with loader, back blade , hydro transmission and 60 hours of light use... Comes with a nearly new Anderson heavy duty trailer... All in: 14k! There is not a scratch on the tractor. Should I upgrade from my b2320? My woods b70x would fit I think... Just need to get a new subframe. Love my kubota but I am being a bit rough on it as it gets a lot of use and it seems a bit too light and underpowered for field work. From what I understand, kioti makes a good machine, and this one specifically is almost twice as heavy..... Help! I think I could sell my b for 9-10 k..,.
/ Need advice! #2
There's a 2011 on tractor house for 16 Gs with mower 29 hours. I would go for it.
/ Need advice! #3
Sounds like a good deal.
Not sure your going to gain the additional power your looking for, for your field work.
Make sure if you spend the money to upsize you go big enough.
/ Need advice! #4
Sounds like a great deal. I suspect for backhoeing and heavy loader work, it will be a significant upgrade, especially if it has loaded tires. I know my CK25 as TLB has be a real workhorse. A buddy of mine has a B21 TLB and it's not nearly as effective at digging, pushing, or ground engagement. I think it's the weight difference. The B21 just seems to be very light compared to my 6000 lb Kioti.
/ Need advice! #5
I loved my CK30 HST with Woods BH-70X, and the only diff. with the CK27 is a couple hp. With loaded tires, it was a VERY heavy machine for 30hp. Here's the negs. to the tractor. 3rd gear is not very useful, it needs more power to move that much weight that fast. The FEL could be a little stronger. This one is a little misleading though. I think the problem is that the tractor is so heavy, when you push into a pile you're able to take too big of a bite and you're lifting against the weight of the tractor. I found I would often have to start backing out of the pile before I could lift it. It will lift a lot more than a b2320 though.
I went from a JD 955 that was about 1700# + FEL & cab, to the CK30 that was 3200# + FEL & BH, pretty close to what you're considering. The difference was astonishing! Trying to break ground with the JD was difficult, while the CK30 could easily take scoops, there was no comparison pulling a box blade or working in the snow. With 3 less hp, the CK30 felt and worked like it was twice the size of the JD.
/ Need advice! #6
I would buy it. I love my dk40 just not my dealer where i bought it. I could touch a kioti dk40 in maine they asked way more . I needed the best deal sense we took a loan out to help a non profit that is having a hard time getting grants and other funding because it first starting out . So the land that was donated need a road and the massey freguson i had just wasn't doing it but when we bought the dk40 the road was done in a month.
I got a call last night from my grandfather that the farm down the road from our old farm that only bought john deere for more then 40years just returned There new 100 hp john deere to many issues in less then a month. And there are having a dk50 se hst and a dk 40se hst and ck 30 for the grandchildren to use on the farm. I think you would be happy with the kioti
/ Need advice! #7
He's not buying a DK series, he might buy a CK-27.
It sounds like it might do what you need it to, depending on what you are expecting it to accomplish for its weight class, HP range and hydro trans. However I would caution to look not just at current need but also consider possible future need for the same reasons you are now thinking about trading up.
If you plan to do a lot of hoe work etc. over time you may want to consider forgoing this deal in light of what you might get out of a DK series Kioti.
Most bang for the buck in most TBN Kioti owner's opinions, and mine as well, and many of the dealers who are frequent visitors to this site, is the DK-40 series is the sweet spot for the Kioti line-up.
The other thing that occurs to me is the current deal includes a trailer which does nothing for your tractor capacity increase- it only spends part of your purchase dollars for something you may not have wanted or needed INSTEAD of further increased capacity.
/ Need advice! #8
CM,
You're right, having owned both, there's a difference between a CK and DK (although, I disagree with the DK40 being the sweet spot). The CK27 is a big step up from a b2320, it is more equivalent to an L2800 with a lot more bells and whistles and a little more weight. Yes, if he wants to keep going, the DK line is an upgrade again, and believe me, a big one. But if his needs were for a DK40-50, it's hard to imagine he would have bought a B series Kubota in the first place. Only the OP can say what his needs are, and having bought 3 tractors in 3 years, I agree, get what you'll need tomorrow today, but what he is looking at is easily twice the tractor he has now. Since the OP may not know Kioti as well as Kubota, the CK lines up (very favorably) to the standard L series Kubota and the DK series lines up against the Grand L Kubota. There's always a bigger, better, fancier and WAY more expensive tractor in the next field.
/ Need advice! #9
Cm,
Yes i bought the dk40se hst for the use of helping a non-profit and when i pay it off i will give it to the non profit for there future use. When i do that i will be buying a small hp tractor most likely a ck or a mf. I looked at ck27 but went with a dk knowing what the retreat would need it for.
/ Need advice! #10
CM,
KK,
Yes, I agree a CK is a step up from the Kubota he has currently, otherwise he likely wouldn't be considering it in the first place :rolleyes:
I'm just suggesting the OP consider for the further reaching future, as well as near future, what his needs are likely to be. If a CK-27 and various implements are adequate then all is well. If, however he is just seeing a shiny almost new tractor deal that could for now, but might not for later meet his needs then go at it eyes open wide.
Regarding a real medium duty work horse in a compact tractor I would say that in the Kioti line up the DK-40 is the real deal, priced right, weight right, sturdiness right, etc., etc. I'm NOT knocking in any way the CK series, I have no experience with them, except what I've read here. Would you say from your own experience with having owned both series, that the CK is to the DK, what the Kubota in question is to the CK?
There's bigger more expensive tractors out there than mine?!:eek:
What now?!:confused3:
/ Need advice! #11
The only "weakness" I see in the deal is the 70x backhoe. It's not the optimum length. In backhoes, reach is very important. Even 6" makes a difference. I have a 7.5' hoe and, while she digs great, I'm continually wanted for more reach. If you don't need a trailer, sell it and the 70x and get a longer hoe, like an 80x. The CK has the weight and the hydraulics to handle it.
And while the CK is no DK, it's a huge step up from a B series for digging. Yet is compact enough to fit into tight spaces.
/ Need advice!
Thanks for all the comments.... Like I said, I loved my kubota but I did find it to be a bit too light for my use. I have a 2 acre lot where I like grow things,... only for the fun if it. Pulling a single bottom plow with a 1400 lbs kubota was a challenge mostly because loss of traction. The loader was a bit weak too... Kioti is twice as heavy, which should help with traction, and it comes with hydro transmission which will help with the loader work. I don't want to go any bigger than this for my use around the house. The funny thing is that I went to look at this deal only cause I was looking for a trailer the guy had in the pictures..... The way I think about it is that I got the trailer for 2 grand, and tractor/back blade for 12K. Seems like a good deal... I'm going for it! Anyone looking for a clean kubota?
/ Need advice! #13
Put it in the Kubota Buying/Pricing forum here on TBN. I'm sure it will get snapped up. Nice looking rig you're getting, and trailer too. Report your findings once you have some hours on her.
/ Need advice! #14
Congrats and Welcome to the pack!!
/ Need advice! #15
KK,
I've found that the best deal can be had depending on what a particular dealer has for stock and when they purchased that stock. I was looking for a DK50 but my dealer could make a much better deal on the DK45 (he had them both in stock). It was pretty much the same price if memory serves as a DK40 since he would have had to order one. It also of course depends on use. I do a lot of road travel in high gear. I also have a cab with A/C that robs 5-7hp. For me I wanted a little extra hp, even though everything else between them is the same.
There's a big difference in the capabilities of the DK and CK, but also in the technology, so it's hard to say if the DK is to the CK what the CK is to the B2320. 4 cylinders vs 3, manual/auto independent PTO vs live PTO, electronic four wheel drive vs manual etc. To the best of my knowledge, the CK and B2320 are both 3 cyl. live PTO etc, so even though there will be a huge jump in capabilities, there won't be in the design of the tractors. I didn't look very carefully at the B line, even though the Kubota dealer I was dealing with (who I bought my first tractor from) pushed the B2920 (if memory serves) because it was compatible in price to the CK 30. What I found to be the closest comparison to the CK was the standard L line. They didn't quite stack up spec wise, they weren't as heavy and had none of the frills the CK had, but if the OP wants to know how a CK27 stacks up, it's the old L2800 (discontinued) so probably the closest now is the L3200. The closest to a DK40 is a L4240, so that'll give him a sense of the difference between CK and DK for Kioti.
/ Need advice! #16
I found I would often have to start backing out of the pile before I could lift it. ......
Sounds normal for just about ANY kind of FEL I've been around ...... you had a HST ...... just adapt ...... not a problem:confused:
/ Need advice! #17
I somewhat disagree. My JD 955 was too light and did not have the traction to push into the pile enough that it couldn't lift the FEL with ease. I've yet to even come close to finding something heavy enough that would fit in the bucket of my DK45 that would be too heavy to lift and I can not only push into the pile and lift away, but push thru the pile while I lift. This is actually a complaint I've heard from CK owners here on TBN in the past, and I agree with it.
Now, I've also used a Volvo wheel loader that I'm sure was well north of 30K lbs and found that if I was still pushing into the pile, it would not lift, otherwise I was fine, I didn't have to actually start backing up like on the CK30.
/ Need advice! #18
<SNIP>
Did you pull back on the stick?!:D
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A64556)
2016 Chevrolet...
2006 Honda Accord Sedan (A64557)
2006 Honda Accord...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2016 Volvo VNL T/A...
2015 Chevrolet Equinox SUV (A64557)
2015 Chevrolet...
60in Hydraulic Forks and Frame Skid Steer Attachment (A64553)
60in Hydraulic...
2018 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2018 Nissan...
