1st tractor, Cub Cadet 7275
   / 1st tractor, Cub Cadet 7275 #1
Ryre
Western Massachusetts
Cub Cadet 7275
After looking at new and used subcompacts and compacts for months, I finally purchased my first tractor. It's a 1997 Cub Cadet 7275 with a Cub 417 loader, one year old 3 pt Blizzard snow blower, 72" MMM, and a York Rake. It has 770 hours and seems to be in good shape, admittedly I don't know much about these machines. Any thoughts or comments about this tractor (things to watch out for, etc.) would be appreciated. I'm sure I will have many questions in the future. I will be using the tractor to harvest cord wood on my property, for snow removal, and maintnence on my gravel driveway.
Thanks,
Ryan
   / 1st tractor, Cub Cadet 7275 #2
:welcome:
   / 1st tractor, Cub Cadet 7275 #3
Hello and welcome to the tractor world.:drink: I can't tell you much about your tractor. Are those the models made by mitsubishi?
   / 1st tractor, Cub Cadet 7275 #4
Welcome to the forum.
I believe those tractors were built by Mahindra.
   / 1st tractor, Cub Cadet 7275 #5
Welcome, congratulations.
   / 1st tractor, Cub Cadet 7275 #6
Congrats on your first tractor! I scored my own first earlier this year, a Cub 7305. I think we basically have the same tractor, mine was just a slightly newer version.
Your cab makes the tractor look... special. :)
Your tractor was built by Mitsubishi, but also probably marketed by Mahindra as a nearly-identical model. I have found that my 7305 matches up with the Mahindra 3015.
Here is someone else's info I scrounged off a quick internet search:
"The Cub Cadet 7000 series was an older Mitsubushi design that went thru several model changes. When Cadet and Mitsubushi parted ways, Mitsubushi sold the design to Mahindra. A 7275 was 27HP and "5" indicated a hydro. A 7300 was slightly newer with 30 HP and "0" indicated gear drive. There was also a 7200/7205 and 7260/7265. The 7300/7305 model had boosted the HP over the 7270/7275 with the same cubic inches and had a new/stronger loader. Woods built the loaders for Cadets."
These seem to be very robust and reliable tractors. Use it within it's limits, and you should get many more years run-hours of trouble-free service! My only tip - DON'T buy your filters from a cub-cadet dealer. They will rake you over the coals, HARD. I buy mine from wix for less than half the price, and they seem perfectly adequate (though opinions vary about this).
Enjoy!
   / 1st tractor, Cub Cadet 7275 #7
It is also similiar to a Case IH 1130.
Thanks for all the info everyone. Deezler, how do you find comparable filters on the wix website? I entered cub cadet parts numbers and there are no results.
Thanks
   / 1st tractor, Cub Cadet 7275 #9
Could you look it up by application?
   / 1st tractor, Cub Cadet 7275 #11
I bought my Cub 7275 about 5 years ago and have really enjoyed it and work it fairly hard, it only has about 1400 hours on it and still runs like new. It has the 417 Loader and a Cub subframe mounted Backhoe that works very well. Excellent machine, you will be very pleased with it. Watch the filter prices as the dealer and Napa really rip you off. I found a replacement air filter at a Ford Tractor dealer that is almost an exact fit for about 1/3 the price, just had to drill out the center mount hole a bit to fit.
There is an issue with the starter relay that pops up on used machines sometimes. Seems that the relay is sized wrong and wired funny so there is an easy fix online here on the Forum Boards that adds an aftermarket automotive or Radio Shack relay with a slight rewiring to correct the problem. Haven't taken the time to do mine yet as I just jump the starter to get it going. It's one of those things on my to do list but not real pressing.
The Backhoe had been on my 7275 all it's life before I got it and when I removed it to use the 3 Point, it won't work more than about a 1/4 movement. I was told it was something on the hydraulic or switch block on the lower right frame under the engine. I tried to adjust the small lever on the H block but it made no difference. Anyone have an idea how to turn on my 3 Point hydraulics on w/o going to the stealer (dealer) for adjustment??
   / 1st tractor, Cub Cadet 7275 #12
Thanks,
Ryan
Hi Ryan, i have the same tractor. it's my first diesel and i have had a noise that is like a bad main brg.???
My neighbor has a 30 hp ford diesel and I don't hear that sound. i just did a main brg. replace on my ford 8n. paid no attention to the cub because it was a diesel but now I'm rethinking it. Does your have that type of noise?
Thanks,
Randy
   / 1st tractor, Cub Cadet 7275 #13
Hi Ryan, I'm also new and not sure my post loaded. I also have a cub 7275, my first diesel. i have a engine sound like a bad main brg. I have paid no attention to it until i listened to a neighbor's ford 30 hp. Much quieter. i just did a main brg. replace on my 8n and the sound was similar. Does your cub have that type of knocking sound?
Thank You,
Randy
Thank You,
Randy
Hi Randy,
So far I'm very happy with my 7275. I can't say that I've ever noticed a knocking sound. Sorry I can't be of more help. Good luck with it!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
