Dumb Question - please go easy on me
/ Dumb Question - please go easy on me #1
VTFireftr
Southern Vermont
Kioti CK 30 gear
I have Kioti CK30 (gear) that currently has one set of rear remotes.
Could I add additional rear remotes by getting a valve body and plumbing that into the current remotes.
Basically, creating additional remotes by just using the current remote and adding additonal valved circuits?
Clear as mud, right?
Thanks in advance for your help and expertise.
Happy Holidays!
/ Dumb Question - please go easy on me #2
Hello from the opposite end of the state!
Try searching "adding rear remote"- there are several threads that discuss adding on to existing systems. I may have subscribed to some fo these but it will take a little bit to scroll through them. Didn't realize i had subscribed to almost 300 thread!
/ Dumb Question - please go easy on me #3
Installing second remote on a DK45 cab
Found this one on the site- not specific to your model but might give you the info.
I went through all the subscribed threads.... didn't find what i thought was there. then I realized- Before i was more knowledgable about the site, I used to bookmark them on the computer.....the other computer.....that doesn't work anymore! :eek:
/ Dumb Question - please go easy on me #4
If you have a set of remotes with PB, then you can just add the new valve in series and feed the new valve PB to the 3pt input.
or
If your current remote does not have a PB, then add the new valve before the old remote.
In addition, if the current remote is a stacked valves, then just add new spool sections.
/ Dumb Question - please go easy on me #5
Happy Holidays!
Do you just want to end up with 2 remotes, or do you want-need more than 2? :confused3: If only 2, you are best off just getting the OEM 2nd set. If you need more than 2, then an electric diverter setup is the way to go IMO. I have a Mahindra 3215 that I need 4 rear remotes on. There is only 1 remote available as an option :mad: and I got that when I purchased the tractor. I installed 3 diverter valves. Very clean and neat IMO. Here are a few pics. :cool:
Thanks for the quick replies.
I already have tapped into the PB port (4 in 1 bucket).
I was thinking along the lines of what MtnViewRanch had done but with manual valves.
My selling dealer has recently gone out, and I really don't want to have to trailer the tractor if it's something I can do myself.
/ Dumb Question - please go easy on me #7
All I said above applies to lever valves.
All valves should have PB to pass the fluid to the next valve.
All valves should be in series using an open center hyd circuit.
