1850 Pump ideas
   / 1850 Pump ideas #11
i also have this picture:
It says Dunfoss and looks like S50....
   / 1850 Pump ideas #12
Laughs - That is just an upside down Danfoss. See this picture:
   / 1850 Pump ideas #13
Here is a better picture and then a close up of the purge port - you can see other allen plugs but they may be necessary for the manufacture of the pump or maybe some people install gages etc.
   / 1850 Pump ideas #15
That's the best picture.
It looks like you have a variable volume tramp pump with a two section PTO pump piggy backed onto it. The one closest to the camera is probably your steering, turning, FEL arms and AUX PTO for the quick attach cylinder. The second section with the larger hoses is probably your main PTO pump. The tram pump is behind that. The silver block to the right is your main PTO solenoid that is controlled by the switch on the dash.
All spculative, of course. :licking:
   / 1850 Pump ideas #16
You can't feed hydraulic cylinders from the tram pump. You should feed them from the AUX pto circuit.
   / 1850 Pump ideas #17
Did you get a hydraulic schematic with your 1850?
It should be easy to add remote cylinders on paper.... routing hoses is another matter. :laughing:
   / 1850 Pump ideas
Wow, it is amazing I keep learing things on this website.
The first pump is PTO, the middle is steering and lift,and the one in the back is tram (wheel drive). I was wondering what was under those hex cover caps but from your guys notes it is Tram driven so the fluid coming out would be under control and not like the PTO (constant). A bummer but not a setback.
Back to finding a line to tap into. Pretty cool you guys had the answers and pictures and thanks Ken for posting yours up.
Carl
   / 1850 Pump ideas #19
Carl,
You might be able to use a setup like mine but Teeing off the aux. pump instead of where I did at the front of the tractor. But I would be concerned about loosing steering. Some sort of priority circuit would need to be setup. There is not much room in the tunnel to run additional lines back to the tub from the front.
   / 1850 Pump ideas #20
I guess he has to decide how he wants to control the cylinder(s) at the rear of the tractor. I was thinking he could put an electric soleniod selector valve in the FEL circuit. That way with the push of a button he could choose to control either the FEL or the rear hydraulics with the same joystick valve. He would have to run hoses from the front of the tractor from the selector valve to the rear hydraulics through the tunnel and that could be a tight fit. I don't know as I don't have that model tractor. There could be plenty of room in the tunnel. That's the way I would do it if I were going to add rear hydraulics.
If you T'd off of the circuit at the pump you'd still have to install a valve somewhere within reach of the operator and as mentioned, you could lose steering if it weren't some sort of priority valve at the tee.
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
New Holland WorkMaster 37 (A53317)
New Holland...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
Weld on excavator thumb EK1212 (A56435)
Weld on excavator...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
