air compressor tank welding advice?
/ air compressor tank welding advice? #1
Longbeard
Member
des moines, ia
case 480c
The compressor shuts off and I hear a leak. I find a crack branching off a weld that holds the compressor bracket to the tank. Anyone made a repair like this before? I've got 7018 and 680 weld rod. Which would be better? I'm guessing 7018.
/ air compressor tank welding advice? #2
I'm guessing "Don't Weld" it. Just asking for a Real Problem and possible dangerous situation. :2cents:
/ air compressor tank welding advice? #3
First I woudn't advise repairig the tank.
Second If your like me you'll try.
is it an upright tank?
could you remove the bracket thats causing stress to the metal most likely thru vibration?
vibration and metal fatigue is most likely the cause, there is most likely more fatigue at other locations around the bracket or at other welded areas.
the pump, belt,pully assembly or motor may be out of balance and continued running will cause more fatigue.
you may be able to remove the bracket, drill a hole at the ends of the crack and weld it sufficiently.
Myself i would weld a relief patch over the affected area after to hold the metal more efficiently.
remount the motor/pump on a suspension pad.
I have patched compressors in the past and they are still running 8 years later. but do keep in mind it is not safe due to unseen damage that is not seen to the naked eye.
The safest bet is not to repair it.
Tom
Yes its an upright. What kind of relief patch? Just a strip of metal across the weld repair i make?
/ air compressor tank welding advice? #5
Yes, you would clean the metal by removing all the paint.
try to find the ends of the crack.
drill a small hole at each end, this is to try and prevenct the crack from growing any farther.
grind out the crack to bevel the edges on each side of the crack so you can get penetration with your weld along the crack.
grind your weld down to the surface of the tank.
a patch of metal the same thickness of the tank, with the paint removed completely where the patch will reside.
form the metal to the shape of the tank surface and then tack it in place.
finish by welding the perimeter of the patch.
it may be difficult to repair due to the fact that most of the time the bracket is located on the top cap and the surface is not flat.
forming it to the shape of the tank is more difficult there.
Once again it is better to look for a replacement tank from a shot compressor due to unseen metal fatigue/cracks.
this is the outcome when one releases. it is not always a small leak.
best to look for a newer tank, and solve the vibration problem.
tank rupture.gifzz air.jpgzz air.jpgzz explosion.jpgzz explosion.jpgzz roch_air_cmprsr_fail2.jpg
/ air compressor tank welding advice? #6
I get the impression that you are not real experienced welder or metal man. If I am right and you just have to repair it, at least get someone to do the repairs that has more experience.
Best is still, get a new tank. Learn to weld & metal work turning this tank into a bar B Q or smoker.
/ air compressor tank welding advice? #7
I've added a few more pics
Tom
Actually I have been welding for 30 years just never welded a pressure vessel. Well I Did but much larger and with a dual shield flux core. I'm just looking for advice and I'm very aware of the dangers. I'll see if I can air arc the crack out if my smaller compressor will keep up.
/ air compressor tank welding advice? #9
Danger Will Robinson.....DANGER.
Fixing that is a realy bad idea. the tank has told you that it is no longer capable of holding pressure- listen to it, please.
From your description, this isn't a weld failure but structural failure.
/ air compressor tank welding advice? #10
First question you need to ask your self.........Hows your home owner's insurance? Second question you need to ask............ How good of a relationship do you have with your insurance agent?
/ air compressor tank welding advice? #11
I had a really nice compressor 30 gal tank etc...the tank began to leak..just a stress crack at the bottom toward the backside of the tank....I junked the compressor....not worth the risk to weld it...I hated it too...just the right thing to do....Why take a chance...?
/ air compressor tank welding advice? #12
ya, its kinda like trying to weld a bomb....:D
/ air compressor tank welding advice? #13
I worked at a ASME certified pressure vessel contractor for a number of years. Even we wouldn't bother repairing our own thin gauge compressor veseels. Too much problem and questions about how far the crystallization progressed from the failure.
You are certainly within your rights to repair it, as long as it's strictly a homeowner use tool. If it has any commercial use, it must be a ASME certified repair, which gets expensive when two boilermakes and Hartford Steam Boiler show up at your door
Advice taken. Looks like im in the market for a new air compressor. The little compressor couldn't keep up and I just made a mess with the air arc. Maybe I could use this 80 gALLON tank for diesel fuel.
/ air compressor tank welding advice? #15
sounds like a good use!
I store my fuel in old tanks outside.
/ air compressor tank welding advice? #17
Wise, wise choice.
Stay from those old compressor--- - WeldingWeb™ - Welding forum for pros and enthusiasts
Repairing compressor tank - possible? - WeldingWeb™ - Welding forum for pros and enthusiasts
These links are from guys that weld for a living. They don't weld to die.
Ok I have some more compressor questions.....I have an old automotive propane tank. I think its about 150 gallons. I usually use it to heat water but I am getting ideas of turning it into an air compressor tank. Steam her out, refit it, use the motor and compressor off the bad tank? Any comments? Ive seen the Amish do it on a larger scale.
/ air compressor tank welding advice? #19
First find the pressure rating of the propane vessel.
Then do a pressure test.
Then do your cleaning etc.:thumbsup:
Metal Rooster Weather Vane (A66738)
Metal Rooster...
2005 Sterling 9500 Truck (A66736)
2005 Sterling 9500...
CASE CX60C EXCAVATOR (A65056)
CASE CX60C...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2004 Freightliner FL70 Water Truck (A68183)
2004 Freightliner...
