How to fix a choker cable?
/ How to fix a choker cable? #1
JD 4520
Snohomish County WA
John Deere 4520
I have this choker cable that I would like to put a loop or something that I can hook a chain to but not sure how to fix it with a loop. Any ideas?
/ How to fix a choker cable? #4
If you use the wire clips... Remember, "Never put a saddle on a dead horse... " Meaning the u-bolts should be on the dead end of the wire rope loop.
/ How to fix a choker cable? #6
Toss it and buy new.
Ditto, by the time you get a couple of clamps it wouldn't be that much more to get a new one. Not to mention, the clamps would be a royal pain in the backside...Mike
Didn't think of that as I most always fix things. Where would I find a new one and what should I expect to pay?
/ How to fix a choker cable? #9
3 -30 foot chokers with loops in craigs list for 30 dollars , not everything has to be brand new or from a store !
/ How to fix a choker cable? #10
Sleeves - MS51844 - LexcoCable.com
Wire Rope, Aircraft Cable, Cable Assemblies | Lexco Cable
Wire rope clips pictured earlier would work if you saddle them right.( use two spaced slightly appart from each other.
they are cheap
I have swagging tools to apply wire cable ends.
you can purchase threaded ends, sleves balls....
if you have a contractor in your area with swaging tools that will assist you I included links to a wide variety of end available(eyelet,threaded...)
I'm lucky I have a local fastner dealer a stones throw from my house he stocks chockers, rivets, bolts, shackles, swagging ends, chain........
Tom
Thanks all, great information. Have a great rest of your day and weekend.
/ How to fix a choker cable? #12
I've used a cable thimble with a couple wire rope clips. View attachment 289438 A picture from farmtek.com
If you work with cable or wire rope it's good to have several of the wire rope clips and thimbles around. I view them as useful as clevis pins, linch pins, lock pins etc. I've used them and reused them, effectively adjusting the link of cable needed.
That's fine if you have the time to go buy a "new" one the exact length you need.
/ How to fix a choker cable? #13
I got rid of wire rope long ago except on my 12.000# winch. Got tired of broken wires, snagged hands and gloves, grease, and stiff cranky handling. If you kink it once with any load you have a usafe link that can go any time. I use nothing but fiber straps and chains now. I am "OLD" Navy so cut my teeth on wire rope. They no longer use wire rope eithe,r since break bulk cargo went away. Production is going down so prices are creeping up. Ought to say something.
Ron
/ How to fix a choker cable? #14
Ron
I agree, but for somethings I need to bind chain doesn't get small and flexible enough. You do need the thimbles to make sure there are no sharp bends.
Seabee - Have you tried the "blue rope" Winch Line, Rope, ATV winch lines, Recovery ropes, Kinetic recovery rope, Snatch ropes, Amsteel Blue. I've read good things about it but haven't yet ponied up the $$ for a long hank.
/ How to fix a choker cable? #16
Newbury,
When I need to choke something a chain is cumberson on, I use a strap and shackles. In fact I use a schackle on both ends of the strap to either hook to a tie point or to attach to a hook. Sharp bends on fiber straps also weakens them severly. I keep a variety (about 12) of shackles in my gear box. I used to do a lot of rigging when I worked as an industrial pipefitter so have this all down pretty pat. That fiber winch line looks greatr but real spendy. Over twice the cost of wire rope. The literature does not address the stretch factor common with fiber stuff. That will be far down on my bucket list. Planning on building a logging winch w/600' of line, may consider it then.
Ron
/ How to fix a choker cable? #17
These gys are right! If that cable fails, it can cut you in two faster than a Ginsu knife through a piece of cheese.
"OSHA" would not approve of the jimmy rig setup, but more importantly, your life and and the of yur workers are at stake.
When our winch cables fail, we buy new, AND make sure there are at least 5 wraps on the drum!
SC
First Choice 6' 3Pt Finish Mower (A66408)
First Choice 6'...
2018 F-150 4WD (A63689)
2018 F-150 4WD...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
IRGC40 High End Mini Golf Cart (A64127)
IRGC40 High End...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
Wooden Bench (A64127)
