Stand alone power source for PTO generator
/ Stand alone power source for PTO generator
The engine is a OM617 naturally aspirated from a 300D, I already have the WINCO 25K Pto generator so, I have both, I was thinking I wouldn't need the governor because the motor would be much larger then the max needed to run that generator so likely after the engine is set at the appropriate RPMs, any load change wouldn't have an effect on the motor that would drop the voltage enough to hurt anything. I could be way off here. All I was thinking was that if I have the engine running at 3000rpms, how do I step that down to 540 or 1000 rpms
/ Stand alone power source for PTO generator #12
I'd think about using a Mercedes transmission with belt/pulley or chain/sprockets on the output shaft. Standard trans in low gear would give you a huge reduction in rpm's and be more trouble free in the long run but Auto should work. There are cruise controls available that use a signal pickup on the driveshaft that should control rpm's within an acceptable range. I've got an old Rabbit diesel I've been thinking about for the same application.
/ Stand alone power source for PTO generator #13
Like my tractor, I rev it up to a point where it is putting out the full 240V as tested on a meter, then just leave it running at that engine speed, there is no governor, and that is why I have a voltage drop when heavy loads are put to it because it is underpowered. To get full output, WinCo says you should have a 50hp tractor, so I'm thinking that with a 80-90 hp stand alone engine, even when loads are put to the motor, it should be way more engine then needed, and absorb those loads seamlessly.
You do NOT set engine speed for generator usage with a volt meter. Engine speed controls A.C. freq. Induction motors, what you will find most commonly around the house are sensitive to being run at correct freq. Conventional electric clocks will NOT keep accurate time if freq isn't correct. You also may have other things around the house that are sensitive to A.C. freq.
/ Stand alone power source for PTO generator #14
In my experience, the frequency and voltage of most generators is more or less linear. Setting voltage will yield acceptable frequency, and vice-versa.
/ Stand alone power source for PTO generator #15
If your motor and transmission was equipped with cruise control, then it could be adapted to deliver an engine rpm which produces the proper 'pto' rpm. I have a 3:1 gearbox that I use on my lawnmower to reduce the high speed pto down to 540 for my WinPower alternator.
You would just need a tailshaft-to-gearbox adaptor to complete the system.
/ Stand alone power source for PTO generator #16
An OM617 won't work for you unless you can figure out a way to strap an external governor. Surplus Center used to have them but it looks like they sold out. Even with an external governor it may not work all that well, I've owned a great many OM617s and none of them had great throttle response. If you can't overcome that limitation you're going to see some pretty serious voltage and frequency drops when a big load kicks in.
Jason
/ Stand alone power source for PTO generator #17
I just used the transmission yoke and universals with a short piece of the drive shaft and turned a plug/ short shaft with sprocket in the back end, into a pillow block, for a skid steer I built years ago.
/ Stand alone power source for PTO generator #18
can the gear box on the generator be taken off and just direct drive it, (most likely it is a 1800 RPM generator), or contact the company and see if they will sell you a plain end plate with out the step up gearing,
most generators that bolt direct to the engine are called single bearing units, as they only have one bearing in the generator/alternator and the engine end of the unit is supported by the motor,
belt drive and PTO have two bearings, so there should be a shaft in or behind the gear box to direct drive (with out gearing)
modern generators, have voltage regulators, and adjust the input voltage to keep the output voltage at a given rate,
the cycles, HZ, is set by RP Ms, 1800 RPM for 4 pole, and 3600 for 2 pole, the governor is used to keep the engine running at a set RPM, (they can be mechanical or electronic) the range of droop should be with in 3%),
Many electronic items need to be keep fairly close to the 60 cycles or they may be damaged, (as time clocks and other things are many times work off the cycles, and motors need the cycles to keep the speed correct. under or over will create heat.
the generator in the picture, I made the bell housing to mate the generator to the engine, using a flex plate to drive it, (like a auto matic trasmision uses)
If a two bearing I would suggest most likely a chain coupling, or some type of coupling that alows some flex in it,
/ Stand alone power source for PTO generator #19
They really have to be, right? Since you can't modify the spacing of the heads on the rotor. But I think the point is that most electrical equipment is more tolerant of variation in voltage than frequency, so if your generator is not perfectly calibrated to deliver exactly 60 Hz / 120 V, it's better to get the frequency dead-on than the voltage.
/ Stand alone power source for PTO generator #20
My point was that Mickey was incorrect. His contention that setting output by measuring voltage would disregard frequency is flat wrong. Setting output with a simple VOM is far better than relying on a series of indicator lamps or an analog gauge on the generator head. Checking frequency establishes a finer level of accuracy, but is not independent of voltage.
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
2010 International 4400 S/A Day Cab Truck Tractor (A59230)
2010 International...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A61165)
2005 Ford F-450...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
