Rock bucket for B3200 loader?
/ Rock bucket for B3200 loader? #1
jim_wilson
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I did some quick searching and nothing popped up on this - so apologies if there's another thread out there that already
covers it.
I am thinking seriously about getting a rock bucket (tined bucket for sifting rocks out of dirt) for my B3200. My property
is infested with rocks - and I have a large pile of dug out dirt that I could retrieve a bunch of rocks from and use for
building stone walls - etc. I've done some looking and the only place that popped out as having a rock bucket in the
size/weight range I would be looking for (either 54" or 60" and as light as possible) - is Virnig . Their solution was a 54"
bucket - in the 500 pound range - and it was a skid steer quick attach style
I'd be looking for probably a 54" bucket - pin on style for the B3200 loader ( I have the Kubota quick attach on the loader -
and plan on sticking with that for the time being)
Any other sources out there I should be looking at?
/ Rock bucket for B3200 loader? #2
You may want to try HLA attachments (www.hlaattachments.com). They make a variety of FEL implements and as they manufacture them here in Canada, they will add on whatever mount you need for your loader ( presuming that the implement is in the right size range).
They have what I think you are describing listed as rock forks and are in the forks category, not buckets.... I have their pallet forks for my B3200 with the Kubota QA.
They appear to have dealers in the US as well as Canada.
Hope this is useful.......
/ Rock bucket for B3200 loader? #3
500lbs is way too heavy for a bucket on a B3200. You are probably going to have to have something custom made to be light enough. I did see a thread on here where someone took a stock bucket and cut a bunch of slots in the bottom to act as a rock bucket. Might be worth a try, a new 54" bucket from Kubota isn't very much, IIRC it is under $400.
The lifting capacity on the B3200 is around 1000 pounds - so it would handle the bucket - but I wouldn't be picking up too many big rocks with it. But yeah - I would prefer to find something that was a little bit lighter to retain some of the lift capability on the FEL.
So far I haven't found anything that meets that requirement.
And yeah - a 54" bucket isn't that expensive. I actually just bought one a couple of months ago because I intend on welding on teeth to it. I'll keep the 60" bucket for snow and lighter materials, use the toothed 54" bucket for digging work, but - I would like to get a "rock bucket" for clearing up some of the extremely rocky soil I have on my property.
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
211771 (A63276)
211771 (A63276)
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
Tree Boom (A62183)
Tree Boom (A62183)
2021 Ford F-150XL (A62180)
2021 Ford F-150XL...
