Snow Equipment Owning/Operating Pictures of your snow weapons
/ Pictures of your snow weapons #1,184
Wow Great Job ! Congrats on a fine finished project snow blower, it does look like the snow had better watch out for you this winter! And some believe there will be lots of the white stuff to move.
DevilDog
/ Pictures of your snow weapons #1,185
Now you just need more driveway to blow:laughing:
/ Pictures of your snow weapons #1,186
Ha... you sound like my wife!!!! I was trired of spending 10minutes doing the driveway, hoping to cut it in half wife this thing. It's actually more for the rink, you need to get the snow up and over the boards.
/ Pictures of your snow weapons #1,187
Plow with a Isuzu npr see what time you save. Leave the pick up at home
/ Pictures of your snow weapons #1,188
Brand new Erskine model 2010 73" blower. Will be the first winter for both Bobcat and snow blower for me. Been used to a cabbed B3030 with rear blower, this should be a treat not having to sit side saddle or twisting my neck.
I added a nice magnetic mount, multi pattern amber LED unit just after these pics were taken. Looks like I'm ready for snow now.
/ Pictures of your snow weapons #1,189
Just put her on today. Unforturnitly I've no cab for my BX, however I'm going to go with the econo model protection from the elements... insultated jump-suit and a set of goggles!
/ Pictures of your snow weapons #1,190
Been there. Sometimes using an old motorcycle or snowmobile helmet helps to keep warm and protect from the elements too!
/ Pictures of your snow weapons #1,191
JJZ 109, nice looking set up. Just wondering if you think you'll need any chains for the skid steer or do you think the added weight of the Bobcat will be sufficient?
/ Pictures of your snow weapons #1,192
/ Pictures of your snow weapons #1,193
Hummmm,
There seems to be some sort of transparent material between you and the soon-to-be airborne snow. How are you suppost to freeze your A$% off in that strange enclosed capsule? hehehe!!
Stay Strong Tractor On,
Phill
/ Pictures of your snow weapons #1,194
This will be the first winter with this setup, it remains to be seen. I'm hoping I won't have to mess with chains. The place that I recently retired from had a similar skid steer setup and never had to use chains. Time will tell.
This machine and blower are definitely heavier than the Kubota B3030 cab with Buhler Farm King 60" blower that I previously had. Never needed chains on that.
Hummmm,
Phill
Believe me, I had my day of using a 60 inch snow blower with no cab. I've kind of grown accustomed to moving snow without bundling up and wearing goggles. :thumbsup:
/ Pictures of your snow weapons #1,195
As much as I want a cab, I can't afford one yet, so in the meantime I use my heated motorycle clothing on the tractor. I just hard wire the controller to the tractor, then plug in when i sit in the seat, and I have infinitely adjustable heated clothing. Its certainly no cab, but it's only a couple hundred dollars and i've never once been cold.
JJZ,
Did you trade in your tractor for the bobcat?
/ Pictures of your snow weapons #1,196
JJZ,
/ Pictures of your snow weapons #1,197
I just finish my preparation for a canadian winter: blockheater for the CK20, Front Martin snowblower, rear stuuded SMT 3/8 chain, and front tryyg 5mm studded chain. Plan B if it doesnt work out good: snowmobile!
Phil
/ Pictures of your snow weapons #1,198
Phil
Nice set up, but what stops you from raising the FEL and ripping the front PTO shaft off by accident?
/ Pictures of your snow weapons #1,199
OOOps, never mind, I just noticed the locks on the lift arms. Very nice.
/ Pictures of your snow weapons #1,200
Phil
Very nice set up, those tire chains are real mean, i had some front + rear on my CK30 for log skidding, makes the tractor unstoppable. Btw i'm certain you purchased from Payeur just by the way your CK20 is set up:thumbsup: Great dealer, purchased my CK30 from them, good people who know their stuff, but far from my place:(.
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2014 Ford F-550 (A55973)
2014 Ford F-550...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
24in pin on excavator tooth bucket (A61307)
24in pin on...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
