adding remotesto my 600
/ adding remotesto my 600 #1
allen6634
hawesville
600 ford
i have been thinking about putting a hydraulic cyl on the top link andboth of the side links so i will need to control 3 cyl i'm hoping to be able to adjust my top link angle so i can get me blade to cut hard if i want and i also want to be able to adjust the angel so i can us the blade more on my ditches i think that with this much control my blade will be more afective how do i add enuff remotes to run 3 cyl at once/
/ adding remotesto my 600 #2
get a power beyond plat and put under the balnk plate on your hyd top cover.. they cost about 100$
from there get a 3-4 bank generic open center DA valve and mount to a convienient place like a fender.
3 can be plumbed to your top n tilt setup, and the 4th can have QD's installed to use as a remote.
a 4 bank valve might cost you 250$.. plus hoses and connectors.. plus the 100$ power beyond plate.
easy build.
sounds like a plan i was looking for a idea if i could do this and here you go and tell me not only can i run 3 i can run 4 wow and the price dosen't seem very bad, i still hav one question though will my tractor s hyd pump run a setup like that
easy build.
any idea where i can get those things?
/ adding remotesto my 600 #5
your max flow at rated speed is 4gpm.
a top n tilt setup takes very little oil.. IE..you are just moving short stroke cyls. . the '4th remote' will be able to use hyd flow up to the tractors capability. keep in mind that as valvs are diverting oil.. other functions downlione will not function. IE.. while lifting top n tilt.. 3pt won't work..e tc.. etc..(temporarily )
are you saying the 3point won't lift? wile i have this hooked up im good if the lift will at lest hold and still lift so i can use my blade.
/ adding remotesto my 600 #7
Antique Tractors - Yesterday's Tractors : Antique Tractor Headquarters
hit the parts section.. ford.. then your series 600 generically.. or the actual model.. like 640, 650, 660, etc.
the hyds power beyond plate is aluminum billet. neds oring set.. etc.
call them. good guys there.
they may or may not have the generic stacking or valve banks. if not.. a low cost hyds supply place like surplus shop will.
some larger farm stores may carrymulti segment valves.. as well as some larger parts houses.
here's a link to ytmag hyds section for ford 600 series:
Discount Tractor Parts and Manuals for Older and Antique Tractors System&r=mcats
here's the adapter plate:
Ford Hydraulic System HV4902 Hydraulic Adapter Kit
(Part No: HV4902) this is a COMMON part.. etc..
i see multi spool valve kits.. but they appear pricey.. look at other options for them valves..
if nothing else you can run 3 singles or 2 duals.. just plumb series.. only 1 function will work at a time anyway.. so no downside.. just a lil more cluttered.
heck a spol function joystick may even work.. though might be hard to get used to.. or could use the joystick for just the top n tilt, and a 99$ log splitter single DA vlave for your spare remote.. etc..
/ adding remotesto my 600 #8
Really no reason to have 2 tilt cylinders. If the tilt cylinder is built properly, you will get an equal amount of tilt to each side anyway. Yes it won't be as steep of an angle, but your tractor can't really make use of full tilt anyway. It's not lake you will tilt a rear blade 25 degrees and pull it along 18" in the ground. You have to make multiple passes and the tractor runs in the ditch, so that in itself puts the tractor at an angle and that angle gets steeper with each pass.
You might want to think about getting 1 or 2 of the valves with the float function.
Good luck with your project. ;)
i'll go with just 3 for now after i get this up and running i might want to add a 4th . does the valves have to bolt to the power beyond plate?i found a nice set of valves last night i would like to run them if possible i was thinking that i could mount the valvs between my legs so i could use three fingers to work them wile i was moving id like to have the levers on the valves set up like the cyl far right ,will move the cyl to make my blade angle middle will move the top and left will give me a ngle to the left. like i said wife and kid uses the tractor so i will have to keep it simple lol
what is a float function? i don't know anything about this stuff i was just thinking that if i hade one on each side it would be better . it might cause me problems and i will just run the three being that you said 4 could be a problem. im depending on you guys im new to remotes i have never used any.
MACK MDRIVE TRANSMISSION (A60736)
MACK MDRIVE...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A60352)
2013 Chevrolet...
2012 HEIL (A60736)
2012 HEIL (A60736)
159120 (A60430)
159120 (A60430)
(INOP) 2008 DODGE CHARGER (A59823)
(INOP) 2008 DODGE...
2014 WESTERN STAR 4900 SF (A60736)
2014 WESTERN STAR...
