Tire Loading Question
/ Tire Loading Question #1
lew61
Eastern Sierras, CA
Kubota L4240HST
I've been quoted the following for loading the r4 tires on a Grand L4240:
50/50% anti-freeze: 2-55gal plus another 24gal(fronts) = $829.33
$45.00 per tire labor.
Does this sound close to fair?:confused3:
/ Tire Loading Question #2
No, it sounds outrageous. Do it yourself. It's so easy. Buy a valve stem adapter from Gemplers or Tractor Supply, buy some antifreeze (amount depends on how low temps are there), and use a cheap 12V pump or some other pump, and fill it. I did mine using 3 gallons antifreeze on each tire and water and labor are free.
Now there are higher tech solutions like rimguard or washer fluid, but unless I was in an area of deep freezes, water and antifreeze work just fine. And why pay someone to do something you can do yourself. I would also be really sad if I paid hundreds of dollars per tire and had a flat and lost it all.
And why load the fronts? Most do just the rears.
/ Tire Loading Question #3
134 gallons of antifreeze plus labor, over $1000.
I put in -35 degree washer fluid in my BX. 20 gallons, $1.40 a gallon on close out at Menards.
Do NOT pay this job! Now I will say that if you were doing this with non-toxic RV antifreeze, you might expect that kind of price.
Thanks for the input. I live in a remote corner of the boonies. Our selection of services is a mite questionable at times. I just got off the phone with a local parts supplier. 0 degree windshield fluid @ $1.19 per gal. I've decided to fore-go loading the fronts. You fellows just saved this newby a chunk of change. I think the fellow with the first quote must have a boat payment overdue.
/ Tire Loading Question #5
I thought the price was outrageous too until I started figuring up price of antifreeze. @ 50/50 mix requires 67 gallon antifreeze (each rear holds 55 gl. & front 24gl. ea). Dealer price $829.33 / 67gl.= $12.38 per gl. Price in stores around here are $13 - $15 for concentrate.
What is normal cold temperature there? Likely do not need 50/50 mix, you don't need to keep fluid at normal water viscosity. Slushy in the tire on extreme cold days is OK, just don't want a solid block of ice.
$8.00 for a drill pump, $10.00 for the tire adapter (priced from TSC) and couple short garden hoses are all the tools you need if you have the jack and air compressor to do it yourself.
/ Tire Loading Question #6
What he said!!:thumbsup:
/ Tire Loading Question #7
I just had the dealer do my rears with methanol and it only cost $121
It gets below freezing here but usually warms above freezing once the sun rises. So, is there any reason to choose anti-freeze over washer fluid? As a young fellow, I worked on a New England dairy farm and the tractor tires would get "slushy" but I don't recall that being a bad thing. I'm going to be using the fel to move a lot of dirt and don't intend to go very fast.:newhere:
/ Tire Loading Question #9
Have you checked the price for Rimguard in your area? I know it varies from place to place, but I was able to get it for $2.25/gallon installed. I can't even touch a gallon of anti-freeze for that price... and Rimgaurd is a heck of a lot heavier.
Living, as I do, in a distant corner of the boonies, I'm not certain of availability. Does Rim Guard have to be purchased from a dealer? Is it available in 55gal drums? :confused3:
I've found a dealer for Rim Guard in Nevada. $3.00 per gallon. I would prefer using it because of its weight and non-toxicity. Guess I have some calls to make to work out some logistics. Thanks for all you help.:thumbsup:
/ Tire Loading Question #12
If it rarely gets below freezing where you are and warms up when the sun comes up, plain water is all you need. Maybe throw in a gallon of antifreeze on each tire for kicks. Cant get much cheaper than that.
In north Louisiana where I grew up on a farm, we only used straight water. It occassionally got so cold that the tires would freeze solid but we didnt need to use the tractors much if at all during the winter so we just waited till weather warmed up and sun shining on the tires would thaw them fairly quickly. Freezing doesnt hurt the tires as long as you dont move them when frozen. Slushy wont hurt to run them so even if using antifreeze, no need to mix it to 50/50 ratio. IIRC for my 16.9x34 tires , 4 gallons per tire would be good to about 20F and it never gets that cold here. You dont need to buy $14 per gallon Prestone either, off brand for $8 per gallon is plenty good for tires.
/ Tire Loading Question #13
I paid $150 to fill my R4 rears with RIMGuard...it was at the time I bought the tractor, so this was probably at cost to them.
I've decided to go with Rim Guard. I spoke with a dealer this morning and he's only a couple of miles from the tractor dealer and will fill the tires once the tractor is in the dealer's shop for assembly @ $2.80/gal. Our winter temps frequently get into the low teens with occasional dips below zero, so freeze protection is a concern. I can see that this forum is a wonderful resource. Thanks to every one who took the time to provide me with input. Now, anybody have advice on how I can quit driving my wife crazy while I wait for my tractor? :D
/ Tire Loading Question #15
...Now, anybody have advice on how I can quit driving my wife crazy while I wait for my tractor? :D
I have a couple solutions for that... but I don't think any of them are legal. :laughing:
/ Tire Loading Question #16
my brother dose tires all the time on the side .. if you want to load with calcium ..every one thinks it is something special ..you get the set up the one guy said to load the tire then get a 45 gal drum then go get 2- 40 kg bags of calcium flakes. yes the same stuff they put on the roads ....first fill the drum 3/4 full add one bag to the water ..never add water to the calcium ....and stir the **** out of it and then start pumping .....the cost around $30 $35 a bag ..i hope this helps and saves you a **** load of cash..... every one in canada uses calcium in tractor tires and it get cool at nights her lol
/ Tire Loading Question #17
Sounds like plain water would work fine.
larry
/ Tire Loading Question #18
Rim guard sounds really good, the closest dealer to me is almost 100 miles each way.
/ Tire Loading Question #19
I've thought about making my own calcium solution because I had tire lose all its calcium when the bead broke as I was getting unstuck from the ditch in a big snow storm last winter. But when I saw how corrosive the calcium was I started wondering about beet juice. Anybody know about that? A sugar syrup for my tires? Sounds sweet!
/ Tire Loading Question #20
they put beet juice on the hyw here in ontario to keep the sand from blowing off and eat the snow ..and its by fare worse then calcium ever thought of being ..eats there trucks up
REDDICK OFFSET DITCHER (A63291)
REDDICK OFFSET...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
2018 Isuzu FTR Landscape Dump Truck (A61573)
2018 Isuzu FTR...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
