Greasing a Massey Ferguson 135
   / Greasing a Massey Ferguson 135 #1
ArcherXC
Swansea, SC
1965 Massey Ferguson 135
I am a new owner of a MF135. How do I tell if it needs greased? And if it does how do I know how much to grease it? One last question. What kind of grease do I use?
   / Greasing a Massey Ferguson 135 #2
You should grease all fittings every 10 hours. 1-3 squirts is all it will take if you keep after it. Up to 10 squirts if the joints are dry. Any automotive red grease should work. This is a case of regular intervals being better than fancy products.
Stop injecting grease after you see fresh grease squirting out of the joint. Wipe off the excess to keep it neat.
Do I grease the lift arms in the same manner? I heard that over greasing the lift arms can ruin the hydraulic fluid because the excess grease falls into the fluid tank.
   / Greasing a Massey Ferguson 135 #4
I doubt that grease would have any way of coming into contact with the hydraulic fluid. I would grease them the same way.
   / Greasing a Massey Ferguson 135 #5
Yep, grease 'em.
   / Greasing a Massey Ferguson 135 #6
After tearing down my 135 this couldnt be further from the truth. Take a look at the pictures in my thread about 135 hydraulics, I had to clean up at least 3-4 cans of old grease caked on to the pump. It was bad enough that the pump was not functioning correctly. So I would grease much more lightly on the lift arms.
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRACTOR (A51243)
2012 MACK PINNACLE...
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
1991 Gmc Top Kick Dump Truck (A50514)
1991 Gmc Top Kick...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
