cub cadet diesel puller
/ cub cadet diesel puller #1
scottyoung
wooster ohio
pulling team
i am looking to put a d1105 kubota in a cub cadet 1641 does anyone know what i need to do as far a motor mounts and also want to know if the hydro would change to the rearend in a 124 cub without much trouble
/ cub cadet diesel puller #2
As much as I like Cub Cadets and Kubotas with some of the best being with a Cadet with a Kubota engine I have several things that I question while writing this. Cadet did use the Kubota engines and I am unsure of the interchangability for them but I'd say the smaller engine with a parts tractor that had the diesel should have everything to make one work.
The larger engine should really bring one to life if it will fit under the hood!
i know that cub put diesels in like the 782 and others but i did not know what the motor mounts were like and how the clutch fit
/ cub cadet diesel puller #4
there is no clutch.
the engine is mounted backwards in the chassis
the 1641 are for the most part identical/interchangeable on most of the hydro tractors
but I doubt most of them will hold up to a bigger diesel than what was in the 782D's especially when in a hard pull and no tire slippage. I have broken multiple axleshafts in a 982.
will a d 1105 fit into a 124 cub without to much fabrication
/ cub cadet diesel puller #6
I don't know the dimensions of the D1105 but I would have to say no, the 124 is a narrow frame model. the 782 is a styled(wide)frame and the engine it has FILLS the framerails of the 782.
so if the d1105 is bigger then it wouldn't fit without major modifications
i gave up on the 124 diesel idea found out that it has a cracked head now looking to put a v twin in for pulling the engine came out of a 1650 repowered i think that it should fit with minor modifing to the frame i have pulled the 124 this summer it did good just want more power . i still want a diesel puller so if any one knows where a good wide frame, perfer a 108 or that era rolling chassy with a gear rearend give me the location perfer that it is close
/ cub cadet diesel puller #8
Here is a D1105 in a 582/782 frame
/ cub cadet diesel puller #9
and NONE of it will fit under the 782 stock sheetmetal, and the 124 is a good 6" narrower!
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
Hardi Pull Type Sprayer (A64047)
Hardi Pull Type...
2017 CAT 926M WHEEL LOADER (A63569)
2017 CAT 926M...
2015 FORD F-550 (INOPERABLE) (A63569)
2015 FORD F-550...
2007  VOLVO G720B GRADER (A63569)
2007 VOLVO G720B...
2013 John Deere 825i Gator (A64047)
2013 John Deere...
