What does this do?
/ What does this do? #1
GMtb42
Gold Member
Spiro, Oklahoma
SOLD Kioti CK20 HST Purchased CK3510SE HST
Like the thread header says; (if lever is moved upward while engine is running it will make a clacking noise and will kill the engine.)
/ What does this do? #2
De-compression valve (aids in starting) Doesn't look like its ever been connected???
/ What does this do? #3
Knew a boy that had an old Yamaha on off road bike, he said the compression release was a jake brake. When I told him what it was he said when I pull it it slows down.:laughing:
Yeah had a old 175cc Yamaha Enduro that had 2 threaded holes in the top of the head, one was for spark plug the other a compression release could be fitted there. Some older bikes had to have a compression release just to start them.
I digress, so if it is a compression release (kinda sorta thought that), WHY? Seems silly to make a working part then not use it.
Things that make you go, Hmm.
/ What does this do? #6
Here is a guess as to why it is there. I had a 3 cylinder marine diesel that that a hand crank for emergencies. If you ever tried to crank a high compression diesel by hand, you'd know why a compression release is needed. Daedong (spelling?) makes diesels for a lot of applications. Maybe small marine engines is one of them. If so, it is easier to just not connect it in tractor use rather than have a separate version of the engine.
"ah~ sokka~"? as they say in Japan, oh wait Kioti is Korean so "Ah... Al-get-sup-ni-da" , I see, so a left over from a probable other usage.
/ What does this do? #8
How does a diesel start without compression? Or do they do something like leave one cyl at full compression?
/ What does this do? #9
You get it spinning and then pop the compression release. It isn't easy.
/ What does this do? #10
First boat I worked on was a tug built in 1944. It had a Cleveland 12V 278 for a main engine. Cleveland became Detroit Diesel and the 278 means 278 cu. in. per cylinder and this was a v12. This engine had blow down valves on each cylinder that you would open and spin engine to blow out any water or oil that leaked into the cylinder before start. Most engines this size are air start. This one was battery start, had 10 8D batteries. When the batteries started to go bad we would open the blow downs on 10 cylinders and leave 2 shut and start the engine on 2 cylinders. Then we would crawl down each side of the block and close the blow downs while they were spitting burning fuel over your head. Don't think this would be considered a safe labor practice today.
/ What does this do? #12
Ya, I'm pretty sure OSHA would have a problem with that method:thumbsdown:
/ What does this do? #13
Wow, I think I would carry an extra battery, or two...
I had this backup hand-crank setup on a 12hp Volvo 2-cyl Diesel and later on a Yanmar 8hp 1-cyl Diesel, both in sail boats. These things have big flywheels (needed with so few cylinders) and I believe I was able to get them spinning fast enough to start via the hand crank. Unfortunately,I couldn't maintain that RPM while using one hand to pop the compression release. I do think that they would have started if a crewman with a second set of hands was available to pop the compression release, but I was always alone at the time. By the way, the crank handle is machined like a ratchet so it jumps out of the crankshaft socket as soon as the motor is turning faster than the starter (me in this case). Having said all that, electric starters are a wonderful invention.
/ What does this do? #14
I had de-compression on an old Kubota and really liked it. It puts less load on the starter because you can get engine spinning to higher RPM before putting compression load on it. Plus allows to spin the engine over for a few seconds to get that cold oil flowing for better lube when it starts.
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Small Indian Statue (A64557)
Small Indian...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
