Logging today
/ Logging today #1
indianaEPH
South Central Indiana
Kubota M59
IMG_1114.jpgI spent the day cutting and moving large oak logs. I have a guy with a portable saw comming next weekend to make some lumber.
The tractor did well but I was limited in lift capability because of lack of ballast. I had a box blade and a large log strapped to the back but was it was not enough to lift the largest logs I have. The rear would just raise off the ground.
Note to self: build a nice 3 point ballast weight......
/ Logging today #3
That will make some real nice lumber.
/ Logging today #4
Looks like fun.
nice grapple set-up.
i'm in the process of building a ballast box for my JD2320 right now something around 1100 lbs+/-
i have a new 200cx loader being delivered tomorrow i hope.
i have intentions of building my own grapple new year possibly.
i want to move brush and smaller logs when cutting our fire wood each year.
do you have a seperate scv or use a soleniod valve to operate your grapple?
tom
/ Logging today #5
That's some serious timber you're moving there. What about your backhoe as ballast? With my equipment - although much smaller than your beast - the backhoe puts about 2,000 lbs on the back... it's the heaviest thing I've got to put back there. Admittedly, the backhoe can be awkward in tight quarters, but from the size of that timber, you're probably not going into close quarters anyhow.
/ Logging today #6
That bottom one is a big log :thumbsup: Makes what I do with my L3010 look puny. Where is the lumber going ??
/ Logging today
Looks like fun.
tom
The M59 has hydraulic 3rd function kit mounted on the loaders and controller on the loader control lever. It is a nice setup. I use to have the grapple on the rear remote on another tractor and it work ok.
/ Logging today
The back hoe would have been an excellent ballast but this property is about 20 miles from my main house and I needed the box blade to do some driveway grading so I could not take both.
/ Logging today
We are building a house and barn. This will go to each building. I'll make timbers for the exposed trusses in the house. The rest will go into the barn.
/ Logging today #10
Nice tractor & grapple set up - looks to be pretty heavy timber to be lifting, I reckon you might be pushing the front axle limit
/ Logging today #11
If you dont have proper ballast, you can put too much strain on front axle. Chain the log and drag it is what I do if its questionable, especially with the hills here in WV. However, that log is not nearly big enough to hurt that M59.
/ Logging today
Ok, got some photo's of the milling operation. We cut 1200bd ft of red oak. It was a perfect fall day in Indiana yesterday.
The mill is a woodmizer 40 hydraulic. Awsome machine
/ Logging today #13
Them bandaw mills do a fantastic job. They leave a fairly smooth surface and have alot less waist.
/ Logging today #14
Thanks for the pictures, we have a bunch of downed trees(thanks to sandy) that are going to become lumber and house heat.
/ Logging today #15
Looks like pretty nice stuff coming off that mill.
/ Logging today #18
Are you stacking them with the stickers (wood block to leave air space between each row). We have had good success with pine drying like this. Your local specialty lumber store should have them. They look like the lath out of the old houses.
/ Logging today #19
Try skidding the logs instead of carrying
/ Logging today #20
Yes, I have a lot of clear straight boards. I hope they stay that way while they dry
I'm sure you have your own favorite way of stacking green lumber so that it will dry right. It's an art....
I like to put down a plastic tarp to keep the ground damp and spores away. Then I use scrap wood or just some old pallets to raise the bottom of the pile a six inches or more above that tarp. Then do the favorite stack type for your area. Use stickers liberally. Top it off however is best for your climate. I like to just lay some (rusty!) scraps of corrugated tin roofing on the top. Every climate is different.
One trick I've learned which really helps prevent checking around here in my climate - which is very dry - is to put a heavy coat of wax or paint on the ends of the boards to seal the end grain. It adds to the curing time, but the wood ends up nicer. The very best wax is "Anchorseal". Expensive, but it goes a long way.
good luck, nice wood.
rScotty
2011 Nissan Juke AWD SUV (A61574)
2011 Nissan Juke...
Case IH Magnum 250 (A62180)
Case IH Magnum 250...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
BLANTON PULL TYPE DRAG HARROW (A63745)
BLANTON PULL TYPE...
LandHonor Chains & Binders (A62183)
LandHonor Chains &...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
