Hydraulic plug caps?
/ Hydraulic plug caps? #1
dhollman
Cazenovia, NY
JD 455
Hi
I just hooked up my JD 455 for winter use (ie putting on the snowthrower) and found the female hydraulic quick connectors on the tractor to be totally full of mud & crud from the summer's mowing.
They cleaned up okay... but I have seen photos of plastic caps that fit neatly in these connectors. But are they a standard type and size? I'm not even sure what to call them... any guidance so I know what to look for would be very helpful. Thank you!
/ Hydraulic plug caps? #2
I have included two separate links to hydraulic dust caps for female QD.
These may not be the correct ones for your application.
They come in sizes for different QD and styles.
Most hydraulic shops should carry them.
They are not very expensive and well worth it.
Dust Covers
ISO 5675 Dust Plugs
Wow, thanks so much for your quick - nearly immediate - reply!
I'll take a look at the links you sent along.
When I am measuring for size, is it the internal diameter of the female part that I should consider? Or... ?
Thanks again
/ Hydraulic plug caps? #5
Thanks again
See attached Spec sheet link. This is for one manufacturer and for 7241B QD's. The ones that you have should have a brand, series and number on them. The format of the numbers varies from brand to brand but if you look at them and state what they are we can probably help determine what you have. Numbers could be something like H3-62-T8, or NV-12-12, or H8-62 or a lot of other options depending upon the brand. If you can supply that it would help and page 3 of the link attached chart may help. http://www.snap-titequickdisconnects.com/qd_pdf/72s.pdf
Its an old thread but I realized I never said a thank you for the info here - I did eventually find a set of caps which work nicely for my tractor and keep the plugs & receptacles clean. Happy new year!
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2023 Cub Cadet Pro Z 972 (A64127)
2023 Cub Cadet Pro...
2014 International 4300 Single Axle Dump Truck (A62613)
2014 International...
32" Smooth Lip Mini Bucket  (A62679)
32" Smooth Lip...
2015 Ram 4500 Service Truck, VIN # 3C7WRKAJ9FG707673 (A65563)
2015 Ram 4500...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
