Does this look "finished"
/ Does this look "finished" #1
Jhossack1
Ortonville, MI
Kubota
I have a newly aquired tiller. The tiller's shaft wont go on the B7100's PTO shaft. The lands look unfinished to me. Slides right onto other tractor shafts - but not mine. Anybody heard of kubotas with unfinished pto shafts? Here's a pic. Does it look finished?
/ Does this look "finished" #2
That B7100 is close to 20 years old. I expect you've got some rust to clean up off the tractor's PTO shaft. Probably some burrs, nick and other minor damage too.
Have you ever had any PTO driveshaft connected to that B7100, or is the tractor new to you?
Nah - its clean. After many attempts to feed the shaft on...and WD40...and wire tooth brush, and clean rag...it wont even start onto the shaft. I give...?
/ Does this look "finished" #4
Same Shaft?
/ Does this look "finished" #5
Did you just buy the tractor?
I bought it new about 20 years ago. I've only had a belly mower on the mid...nothing ever on the rear PTO. Just blades and trailers etc. on the 3 pt. hitch.
Not sure I get your question. I took the tiller's shaft into the Kubota dealer, the mechanic slid it up onto another cat 1 tractor, like a dream. On The good tractor shaft, the lands looked chamfered and the female slid on for about a half inch before the collar had to be slid to allow full-on connect. No problem. He says all PTO shafts are the same. Guess I'll have to trailer it in.
Same Shaft?
/ Does this look "finished" #8
Well, he's right...shame you didn't notice this when you bought the tractor.
Let us know what the dealer determines...
/ Does this look "finished" #9
In the far dark caverns of my memory storage I seem to recall different splines for Japanes home designated Kubotas as having different splines and maybe even different rotation???:(
/ Does this look "finished" #10
Good point, Egon...the OP may have a grey market machine.
/ Does this look "finished" #11
To me it looks like there are small splines between the larger ones? Or is that an illusion?
To DT86 - I don't know, but I will look hard for burs or whatever before I go hauling it back to the dealership.
/ Does this look "finished" #13
Try a wire wheel on a cordless drill if there is any crud/rust on it. Then try to hook the shaft to the tractor with out the other end connected to the implement.
Are you sure you had everything lined up properly? As in, the splines on both shafts and everything inline with each other. Is the shaft sliding in and out as it should?
I have cleaned it up with a wire brush (handheld). The female wont even start onto the male tractor shaft - at all. The female shaft for the tiller is operating fine - tested at the dealer today.
/ Does this look "finished" #15
Do you think your machine is grey market?
/ Does this look "finished" #16
Well your shaft out of the tractor doesn't look like pto shafts ive seen before. Should just be straight channel from the front to the back. It almost appears to be some kind of upside down v in the low spots on the shaft. If that is true I don't think your shaft is going to line up.
I dont think so - but not sure - just because I have no idea what "grey" market is. Bought it from a dealer in Pontiac Michigan close to 20 years ago.
/ Does this look "finished" #18
Grey market machines are designed for use over seas and have found their way to the States. They lack safety standards required in the US and are also different in other ways, the odd size reverse rotation pto mentioned earlier, stickers in Japanese, ect.
/ Does this look "finished" #19
Spline looks different.
If it's only those small splines and all else is the same, just grind them off. I have done it with a hand held grider and all worked fine.
Accurately measure first.
/ Does this look "finished" #20
When you engage the PTO which way does it turn? Grinding may be a waste of time if it's reverse rotation.
2014 J&M 375ST Seed Tender (A63116)
2014 J&M 375ST...
John Deere 750C Dozer (A64047)
John Deere 750C...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
207280 (A52708)
207280 (A52708)
208320 (A58375)
208320 (A58375)
