At Home In The Woods
/ At Home In The Woods
Thanks for the kind words guys. I have to say I am getting more than a little satisfaction from the completion of the porch project. My wife did the design work and spec'd out all the materials. I'm pleased with how her design turned out. We still have a few little things left to complete, screens, screen door, staining the wood, etc., but the porch and deck are finally usable!
My wife built a fire in the fireplace yesterday and today. The fire felt great on a couple cool overcast days. But it underscores how far behind I am in cutting and splitting firewood for this season. It looks like I will be burning not-so-seasoned wood again this year. I have a little cut and split but probably only enough for 1/3 of the winter. Maybe I'll be caught up before next year's wood burning season starts.
I've been remiss in uploading pictures. I built the porch steps and temporarilly propped them on some wood blocks so we could use them. A friend's son helped me build them.
On Saturday I took the day off and went whitewater kayaking. When I got home I discovered that my wife had moved the steps and started the prep work for putting the steps on their final base. She scraped off the gravel and dug out some red clay dirt. I took over and finished the job. I added gravel to provide a level base that would give the steps the correct height. Each step is a 6 1/2" drop. After leveling out the gravel we sat the steps in place. They feel rock solid when walking on them.
Also, you can see that my wife has finished staining the posts, railing, and rim joists. She also stained the steps.
We will take a break from working on the porch and deck for a while. At some point we will install removable screens on the porch.
My next priority is firewood.
Here you can see what is under the steps. A year ago when we were grading the yard, we reinstalled a drain line for the roof gutters. The grading contractor had installed the drain line under the spot designated for my wife's herb garden. So I dug up the errant drain line.
We installed the new drain line in a better spot.
In preparation for the porch steps, we installed a French drain under the gravel and connected it to the gutter drain line. In this way, the top of the gravel under the steps could be level with the surrounding topsoil but not turn into a mud hole.
/ At Home In The Woods #4,366
Last night we bought this stainless steel gas grill off of Craigslist for $20. It's in fairly good shape. All the igniters work. One of the 3 burners is starting to rust out but is still useable. A set of 3 new burners costs $13 online. One of the casters does not work. For under $50 we will have a very nice grill when done.
We got our previous grill for free when someone put it out on the street for trash pickup. We replaced the burner for $10 or so bucks and used that grill for 10 years. Our "new" grill is in much better condition than the old one. Unfortunately, the new grill is very heavy so we will need to get the casters working.
i got one of those $15 replacement burners for my charbroil. It lasted a year? It was a stainless one too? My grill sits under the carport so its not like its getting moisture from rain on it? The grill gets a bit of blown rain onto it is all?
Yes, these days it seems really difficult to find quality stuff. Almost everything is made in China.
Obed
Our new grass has come in quite well. I need to keep the leaves off the new grass to keep from smothering the grass. Here's how I rake leaves. Raking by hand is for the birds.
/ At Home In The Woods #4,369
That tall green grass doesn't help your leaf problem all that much. Your grass is gorgeous, but it sure will catch leaves. I like to keep mine trimmed so a gust of wind will blow the leaves into the woods. Of course, more leaves blow into the yard too, but it makes a good excuse for not raking leaves. I will probably put my mulching adapter onto my mower before cutting again. Like you, I am surrounded by trees.
About the grill's burners. . . About three years ago, I had a Charbroil Big Easy grill that had seen better days. My wife let me buy a new Weber and I thought I'd fix the Charbroil and sell it. I ordered a burner repair kit for not much money and installed it. In the process, I found that I had removed the burner shield plates when I originally put the grill together. Cooking meat could drip right onto the burners. The old burners were more rust than anything else. After installing the new burners and the shields, I also installed a battery powered igniter to replace the broken piezo-electric one. The darn grill worked like a new one. It worked so well, I decided I couldn't give it up. So now I have the Weber on my deck on the east side of my house where it is out of the afternoon sun and my Charbroil on the west side of my house in the shade of the raised deck on that side. I can grill on either side of my house. I guess grills are like tractors. You can NEVER have too many.:D The burners in that old grill are still working fine after two seasons, but it may be because the grill only has to do half as much work now that I have the Weber. I love the Weber, but that old Charbroil is still a good performer.
Yes, I already have leaves all over the yard again. But that's ok. Sitting on lawn mower is much more fun than raking. My wife gets all the credit for the grass. A few weeks ago she put roundup on the onwanted junk that came from the straw we put on the yard when we first seeded last fall. She then re-seeded and fertilized. The yard looks much better now. It has the grass we wanted without the extra stuff. We'll just have to see how it survives next summer.
Obed
/ At Home In The Woods #4,371
Obed
Obed, I agree with Jim, I have bermuda grass and keep it cut at no higher than an inch....I don't know what kind of grass you have ---Is it Fescue ? I have found the higher the grass is left the more disease it will encounter and as Jim said it will hold the leaves....Just a thought...sure does look pretty ..you have a great stand of grass..
My wife made some gardnenia cuttings from some bushes at one of the offices where she works. She planted them beside the front porch. She did not think we had deep enough topsoil in that area. So she scraped off the existing leaf mulch and topsoil, removed some red clay to about a 1 foot depth, then added more topsoil. She planted a couple gardenias and reapplied the leaf mulch around them.
I used the wheelbarrow to cart off the red clay to a dirt pile. We had a little help with the backhoe.
Bob,
Yes, it is fescue. I've debated cutting it short but am nervous to cut it that short while it is still so new. Maybe it doesn't matter. I don't have much experience with growing grass.
Obed
/ At Home In The Woods #4,374
I am no grass expert and you would know it if you looked at my yard. From what I read 3+" is the best for fescue. I cut at 3 1/2 during the hotter months and 3 during the cooler months. I also read that as new as your grass is you want to protect the developing root system by leaving it on the longer side. Hey, I read it on the inter-net so it has to be true, right.
MarkV
/ At Home In The Woods #4,375
Yes fescue is a bunch grass, which means what it sounds like. It needs to be kept taller one so that that dark color is had but also so that it does not look bare, as it grows from clumps unline a running grass like bermuda that has runner shoots and blades going everywhere.
It is a fickle and expensive grass to maintain from what i understand. From what i understand it likes water and fertilizer to stay healthy.
Fall Pictures
I've enjoyed the fall colors tremendously this year. It helps not to have a bunch of projects with deadlines hanging over my head so I can look up and smell the roses. This is the last week of daylight savings time. Getting stuff done outside slows down this time of year with the shorter days. I guess there's a reason things are designed this way.
attachment.php
/ At Home In The Woods #4,380
Those are some great pictures....Be careful not to cut the red ones by accident :) The place has a maturing look about it, shows all you and your wife`s hard work.......Tony
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2007 FORD EXPEDITION XLT (A62130)
2007 FORD...
2015 Chevrolet Caprice Sedan (A61569)
2015 Chevrolet...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2013 PROCO KILL TRAILER (A60736)
2013 PROCO KILL...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
