Replaced turnbuckles with telescopic stabilizers
/ Replaced turnbuckles with telescopic stabilizers #1
Baby Grand
Elite Member
Windsor, CT.
Kubotas: L3240GST B2320HST B5100D & G5200H
Just replaced the turnbuckles on our B5100 with telescopic stabilizers from StabilWorks:
StabilWorks
The installation took about 20 minutes and they are a huge improvement.
Hitching an attachment is much faster now. I had considered Pat's, but didn't want to move the mounting point any further aft.
Our B5100 can only manage a little over 300 lbs on the 3 point and we have a 40" tiller that it just manages with the present geometry.
Mark was very helpful and warned that I might have to trim the PTO guard a bit (it's close, but so far no clash).
I highly recommend these as a very affordable upgrade to anyone who frequently changes implements and wants to preserve their present hitch geometry. Cast off the turnbuckles of oppression!
Jim
/ Replaced turnbuckles with telescopic stabilizers #2
I just installed mine yesterday, It's the best money I've spent on my little B7200. Mark is very helpful and make's a great product.
/ Replaced turnbuckles with telescopic stabilizers #3
Is there a reason no one gives the price they paid for the actual one they rec'd? I hate calling for a price and finding out something is about 5 times more than I'll pay and that's always my assumption when a seller doesn't give a price or even a price range so I just move on.
/ Replaced turnbuckles with telescopic stabilizers #4
thanks for the reminder BG...I've been wanting to trim back the PTO guard for some time now but somethings else always comes up. Good luck with the telescopic stabilizers
/ Replaced turnbuckles with telescopic stabilizers #5
Looks good.As I mentioned in another thread I made a set for my BX 2360 and find them to be a definite improvement over the turnbuckles.Just curious what the tab is for on each one?
The tabs are parking spots for the pins while you are adjusting the length so you don't drop them.
I paid $131 for the set, which included shipping.
Very reasonable price for a well made, hand built product that works right.
I thought about making my own, but couldn't find exactly the steel sections that I wanted and knew that there would be a lot of trial and error to get everything just right - there isn't much room in that area on the B5100.
/ Replaced turnbuckles with telescopic stabilizers #7
I also paid $131 to my door.
/ Replaced turnbuckles with telescopic stabilizers #8
I have seen him have them listed on craigslist.
/ Replaced turnbuckles with telescopic stabilizers #9
Thanks for the price. Seems reasonable for those of us that don't weld. Not cheap but reasonable. Also thanks Naildriver, TBN is not functioning properly and couldn't add your to the same reply.
/ Replaced turnbuckles with telescopic stabilizers #10
I can answer that. I build three different sizes, to suit the owners tractor size and needs. Within those three sizes, there are often differences in tractors, which leads each set to be custom made. So, I price them based on the size, in addition to unique needs. In most cases, the prices are the same- $120 plus shipping for a small set, $130 plus for a medium set, and $140 plus for a large set. That is standard- in 98% of the cases, that price never changes. I use flat rate shipping, so there aren't variations in the shipping price, unless the customer lives outside the continental US. If a customer needs heim joints, etc., or if the set is excessively long (more material), I charge extra for that. But, I only charge the hardware/material difference, because the labor is about the same. So, when a customer contacts me with their needs, I give them a price then, and it doesn't change at that point. If I miscalculate, I absort it, not the customer.
/ Replaced turnbuckles with telescopic stabilizers #11
I have two sets on the way for my BX's, it will be a welcome improvement and Mark is great to work with.:thumbsup::)
/ Replaced turnbuckles with telescopic stabilizers #12
Have to agree.
My set for the BX2200 is due to arrive today or tomorrow. I agree, Mark (screen name "hodge") has great communication, sends photos of your set(s), and keeps up with e-mail.
Edit: The set did arrive today. Very well packaged, clear indication of what goes where, and well made and finished. Welds look good. It will last the life of the tractor. It is obvious that Mark takes pride in his work.
Installation tomorrow (weather permitting).
/ Replaced turnbuckles with telescopic stabilizers #13
Thanks to this thread, I got a set to put on our B7500. Great communication from Mark and they were exactly as described. One note, the tab is no longer on there (unless you request it), he now just uses a short chain.
Installed on both sides with an old turnbuckle on top for comparison:
Closeup of the one on the right side:
Installation was simple, I cut the turnbuckle link off of the tractor end, pinned the stabilizer in its place, unbolted the other end of the turnbuckle from the lower arm and bolted the new bracket into place. I think it took ~30 minutes INCLUDING driving the tractor to my inlaws, getting out the tools and putting them back away. I am very happy with them.
They will help keep the trailer from jamming up on the lower arms and will make attaching implements a much easier exercise.
Aaron Z
/ Replaced turnbuckles with telescopic stabilizers #14
Hmm, would anyone with a BX have a pic and/or the open and closed lengths for the StabilWorks stabilizers? Thanks in advance.
/ Replaced turnbuckles with telescopic stabilizers #15
Don't have mine on yet, but will post pictures when I do if no one else shows up with one.
/ Replaced turnbuckles with telescopic stabilizers #16
Chris, a BX25? I haven't built a set yet for a 25, but I build them for a span of 13"-16", pin to pin, for other BX models (the 25 should be the same). That is the sweep of the lift arm- they will open farther than 16". I will post a photobucket link of a BX stabilizer.
A standard set for a BX2360-
BX2360001.jpg picture by br549_red - Photobucket
A custom set with heim joint, BX2360-
BX2360custom001-1.jpg picture by br549_red - Photobucket
Mark
By the way, the sets in the photos aren't painted yet. I prime and paint them before shipping.
/ Replaced turnbuckles with telescopic stabilizers #17
TripleR, did yours show up yet?
/ Replaced turnbuckles with telescopic stabilizers #18
/ Replaced turnbuckles with telescopic stabilizers #19
Not sure if this is relevant, but for the BX2200 the stabilizers open and close far enough to span the full adjustable width of the lift arms. In other words, the lift arms run out of adjustment in narrowness and greatest width before the stabilizers do.
Due to the variety of hole placements there are many, many adjustment choices between the two extremes. The stbilizers will work great on my variety of implements, some homemade, that have different pin widths.
/ Replaced turnbuckles with telescopic stabilizers #20
Mark
Thanks Mark. Will have to take some measurements tomorrow but a set of these will likely go on my want list. Seems I'm adding to the "want" list faster than I can fiscally obtain what's already on it. Got's to plant me one of those money trees one of these days. :laughing:
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
New/Unused Wolverine 72in Quick Attach Rock Bucket (A65583)
New/Unused...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
JCB 3TS-8T TELESKID SKID STEER (A65053)
JCB 3TS-8T...
