BX 2360 Oil Change
/ BX 2360 Oil Change #1
bx2670
Pilot Mountain N.c.
2013 Bx 2670
I did my second oil change at 111 hrs today.The first time I used Rotella 15-40, this time I used Rotella T-6 5w-40 fully synthetic anyone using this oil ??? Also replaced air filter it was dirtier than I figured it would have been from mowing grass.
/ BX 2360 Oil Change #2
Nope, never really cared for Rotella. Always seemed to make the engine run louder in my truck.
Honestly, in a tractor unless you are shooting for thousands of hours on the engine, I personally feel it is a waste of money. In a truck or car, I do run a synthetic.
/ BX 2360 Oil Change #3
I used to use Rotella 10W-30, but recently I couldn't find it. So now I use Rotella T-5 Synthetic Blend, also 10W-30. I recently turned 1,000 hrs with no engine problems.
100 hrs is about all I get out of an air filter also.
/ BX 2360 Oil Change #4
I use T6 Rotella and I have no complaints. I noticed the engine was less noisy on cold mornings with the synthetic Rotella. The cost difference is not a lot for the tractors and generator.
/ BX 2360 Oil Change #5
At my 50 hr change (BX25) I used the T6 Rotella 5w40. I have it in my 2000 Jeep Cherokee too and don't have any complaints. I expect to have nice easy starts this winter when I have to plow the driveway in 10 degree weather. I feel a little more comfortable using a synthetic for the few extra bucks that it costs. It's probably no real advantage over standard high quality diesel oil if you keep up with the recommended oil change interval.
/ BX 2360 Oil Change #6
Most oils do just fine if you change at regular intervals. If you are in colder climates at start up a 5w-x is going to be better than a 15-x. If you abuse the oils, that is when the oils really show their colors. Normal use they are pretty much equal.
/ BX 2360 Oil Change #7
Not true! Synthetics shine in all weather conditions, especially cold starting. If you have ever started your tractor at -40, then you would be greatful for synthetic.
OP, we run either T6, or Valvoline 5W40 syn, both are excellent oils.
/ BX 2360 Oil Change #8
Here I thought you was running a good oil! Just busting your chops.
Most people generally never keep a tractor long enough to make a difference on the type of oil they use was my point.
Honestly though, unless you abuse your tractor, you are never going to see an oil related issue and if you do have a problem, it is going to be arguable that it wasn't a part failure in the first place.
-40 or not synthetic ought not to make a difference since a x-40 weight should be the same viscosity regardless if it is synthetic or not.
/ BX 2360 Oil Change #9
I must agree with you! Dino oils have advanced so much in the past twenty years, it is amazing. Look at Delo for example. Up here, synthetic is not much more than dino, unless you buy boutique oils like RP, Amsoil, and the like.
/ BX 2360 Oil Change #10
I just changed to synthetic oil in the BX2660 and now I'm going to change the HST to synthetic also.:thumbsup:
2014 Ford Explorer (A62613)
2014 Ford Explorer...
Transfer tank (A61567)
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A61574)
2012 18ft Gastron...
2022 EZ-GO ELITE...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
