Emergency flashers
/ Emergency flashers #1
Nelson Farms
Mississippi
John Deere 5520 Massey Ferg 383 and 1035 compact
Having problems with my emergency flashers on my John Deere 5520 cab. The signal lights work fine but the flashers doesn't work.
/ Emergency flashers #2
Have you checked for a blown fuse?? Possible faulty warning light switch.
I checked all the fuses and relays I noticed that only my regular beams on lights work so it may be the switch.
/ Emergency flashers #5
Different tractor, but on my 2305, the problem ended up being a blown diode, located in the wiring harness behind the instrument panel cowling.
/ Emergency flashers #7
Does that tractor use a mechanical blinker module? If so, remove it and either check voltages on or short across the pins on that connector. Sometimes just flicking it with your finger will get one unstuck.
/ Emergency flashers #8
Thanks for the link Chipsndust! Mine stop working this summer.
/ Emergency flashers #11
Thanks for the info.maybe that's my problem.
/ Emergency flashers #12
I ordered my diode, $12.00 here in Canada. My signals were the first to let go, then my flashers a month later. Will let you know if it fix my problem.
/ Emergency flashers #13
Good luck Henri, the diodes are very small and plug into a receiver.
I saw three diodes in the harness, one large and two small. On my tractor, it was the small diode highest on the harness that failed. The diodes were taped to the wire bundle with black electrical tape, they may be difficult to find.
There is probably a special tool for removal; I carefully used a small knife blade to depress the internal lock and slide the diode out of the receiver.
PM me if you have questions.
/ Emergency flashers #14
Thanks Chipsndust! Have received the diode and going at it today.
/ Emergency flashers #15
Job finish, problem fix. :cool2: Chipsndust, I owe you a case of beer. :drink: You probably saved me a lot of aggravation. Thanks for taking the time to post your fix.
Stingray, I suspect that you may have the same problem, please give us an update once you have your problem fix. :)
2018 Trail King Lowboy (A63118)
2018 Trail King...
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
7102 (A61567)
7102 (A61567)
500 GALLON FUEL TANK (A62131)
500 GALLON FUEL...
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
2014 Ford Econoline Van, VIN # 1FDEE3FL6EDB17703 (A61165)
2014 Ford...
