F450 woes
/ F450 woes #1
brain55
Brentwood, CA
I love my 2008 F450, even though I'm a GM man, but I broke my 6.4l. Last week I was towing my trailer over a little grade like I do, at least a couple times a week when I heard it start knocking. At first I thought it was just a weird echo off the hills, it was only noticeable at an idle. The next morning I got up and started it, it was definitely knocking, I didn't think it was a lower end knock. I took it to the dealer and they found a broken rocker arm. So they ordered new rocker arms and installed them. When they got it running again it was still knocking. Next they pulled the cab and disassembled the top end and found it had wiped a cam lobe, again put it all back together only to have it knock still. At this point they are waiting for the factory rep to give them the ok to pull the motor, they seem to think it spun a rod bearing.
Personally I would have pulled the pan to clean out the metal and inspect the bearings anyway. Luckily it is still under warranty. I have 91,000 on the 100,000 warranty. I really hope they replace the motor.
Brian
/ F450 woes #3
What do you think could have caused this to happen Brian? I know you are a mechanic and very knowledgeable. Do you think it was the load or just a weak or bad part in the engine?
I have had the opportunity to drive a few F-450 and F-350's with the 6.4 motors and they seemed very strong but I was not really impressed with the MPG's when I compared it to the other diesels I have owend and operated. 99 F-350 7.3L, 04 F-250 6.0L, 05 K3500 6.6L, and a 06 F-350 6.0L
Chris
/ F450 woes #4
Wow, sorry to hear about your truck! I've never dealt with a factory rep in the auto industry, but is there a way you could get involved with them one on one? I'd be pushing pretty hard for a new engine.
I guess to be honest...I'm a Ford guy, or maybe I was. They've made it pretty tough for us guys that prefer to purchase lease turn ins and low mileage used trucks with the 6.0 and 6.4. I'm leaning Cummins for my next purchase.
/ F450 woes #5
Hate to tell ya but that stuff is just not out of the ordinary for the 6.4. I know of several trucks that have had multiple engines replaced with less than 50k miles.
Ask them if they will do a Cummins swap. lol Atleast you'd have a reliable engine in there. The cab and chassis 6.7 PS seems to be problematic around here also.
/ F450 woes #6
His is not a Cab and Chassis, its a pickup F-450.
Chris
/ F450 woes
Chris
I would guess the metal from the cam did the damage. The service writer made it sound like cam failures were common, but bottom end failures weren't as common. Hopefully I'll find out more today.
/ F450 woes #9
Yes cams are quite common. Even the drive for the high pressure pump will wipe off. Have seen a couple that have had the piston cooling jets fall out too.
/ F450 woes #10
Hopefully it will be totally trashed. That way a new Long Block will be installed.
Chris
/ F450 woes
Chris
That's what I'm hoping too. I was figuring on trading it in early next year when the warranty was up, but if they replace the motor I will probably hang on to it for another year.
/ F450 woes #14
Go to powerstrokehelp.com and check this guy out and his videos on YouTube. Has a lot of knowledge seems like. Goes through all the fail points of the 6.4. The emissions system kills these things. I want to delete it on my 450 but worry about being tested by dot. The fine Im sure would be outrageous. You may already know all this but if not check it out.
/ F450 woes #15
just curious.. but what oil were you using.. and what interval?
/ F450 woes
I use DELO 400 15/40 like I have for decades, I try to do 5000 miles but I have stretched that at times to 6-7000 I'm putting 3000 miles a month on this truck.
/ F450 woes #17
delo ain't bad oil..
I'm using the valv premium ultra blue 5w40 full syn.
do they think it was a lube failure on that cam issue? or? what?
/ F450 woes
They haven't given any indication yet. I talked to the service writer earlier today they were hoping to have the engine out today and have it apart Monday morning. Considering my dealer has done several cams in 6.4's I'm thinking it is more of a manufacturing (soft cam core) issue. I am thinking the metal from the cam failure caused the bearing/lower-end problem. But it could have gone the other way too. I could have lost a rod bearing, allowing the piston to get up into the valves creating a valvetrain issue since it had a broken rocker arm.
/ F450 woes #19
Hope they take good care of you and your truck, the day my 6.0 turned 5 years old I bought another
150.000 mile warrant for it. Anything that you have done to one of these trucks cost $2500.00, so I
thought it was cheap.
Doug
/ F450 woes
Doug
I'm fairly comfortable that they will, my only apprehension is from stories I have read on the internet. The service writer without prompting essentially told me not to worry that it would be covered under the warranty while handing me a PO to get a rental car at their expense, not Ford's.
159120 (A60430)
159120 (A60430)
2015 Chevrolet Silverado Pickup Truck, VIN # 1GCNKPEH7FZ334229 (A65563)
2015 Chevrolet...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
BUNDLE OF R19 INSOLATION & RD DUCT INSULATION (A64281)
BUNDLE OF R19...
PALLET OF MISC 3/4" PVC PIPE, MISC FITTINGS & PART (A64281)
PALLET OF MISC...
2013 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2013 Freightliner...
