HPX 4X4 Gator Electrical Problem
/ HPX 4X4 Gator Electrical Problem #1
simonds
Steuben Co. N.Y.
John Deere 4200
My battery goes dead in about 2 weeks after charging. I checked the system with a tester and while runing it is reading 14.5 volts at the battery. So I'm assuming it is charging ok. I have checked for bare wires under the box and all looks fine. The key is off, so what could be draining my battery? Thak to any replies. Clayton.
/ HPX 4X4 Gator Electrical Problem #2
Review this You Tube Video and see if it will help you locate the problem. I would advise replacing the fuse if you pull it and see no change on you meter. Nothing like having a pile of 5-10-15-20 amp fuses and not know where they go.
How to check for Current Draw on a Vehicle - YouTube
/ HPX 4X4 Gator Electrical Problem #3
John Deere 1418 Bush Hog (A64047)
John Deere 1418...
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
1000 GALLON POLY NURSE TANK (A63290)
1000 GALLON POLY...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2008 FORD F-250 SUPER DUTY (A63569)
2008 FORD F-250...
