Electrolytic Rust Removal
/ Electrolytic Rust Removal #21
Or a DC welder, if you are impatient like I am. When the bubbling is fierce and the solution is getting warm in the tank, you know you are doing a good job.
That's funny! Are you sure you are not boiling water??? Using that much power would scare me to death!!
/ Electrolytic Rust Removal #22
i recently picked up a 2/10/40/100/200 starter charger.. the 40a setting is 100% duty cycle. will boil a small part.. or a large part like a hood in a big tub can be covered!
/ Electrolytic Rust Removal #23
make sure it is outside and in ventilation.. and no sparks! and don't let anodes touch work pieces!
/ Electrolytic Rust Removal #24
Like I said, I havent tried sodium carbonate, but it sounds like it will work. As for using bicarbonate of soda, if you heat the bicarbonate to 200F, it will release the carbondioxide and water and become sodium carbonate. I dont know which would be the cheaper material to purchase, but everybody has a box of Arm and Hammer baking soda in the fridge.
I am wondering what would happen if someone tried phosphoric acid in the place of the sodium carbonate. P-Acid will chemically remove rust without electricity. Might work, and then again, it might blowup, I will have to do a little more research before I try it.
/ Electrolytic Rust Removal #25
ph+ addative for a pool is pretty durn cheap .. no heating needed....
your call. there's plenty of reading on electrolysis on the net. read it up.. lots of possibilities...
/ Electrolytic Rust Removal #26
I read somewhere where someone used clean paint can lids, to get more surface area. Maybe like a quart can lid would fit in there, tacked to something.
I used my old Sears and Roebuck 20 amp 100% duty cycle charger, but think I found a new use for my old Century AC/DC welder that's been collecting dust for 20 years..!!
/ Electrolytic Rust Removal #27
You might try just filling the pot with Muriatic acid, no electrolysis. It's available at building supply houses, Home Depot, etc. It's commonly used for cleaning brickwork. It will take off some pretty serious rust. It's also used for Pickling steel to remove mill scale. Won't damage the metal.
...I dont know which would be the cheaper material to purchase, but everybody has a box of Arm and Hammer baking soda in the fridge...
My box of washing soda was about $3. It was in the laundry aisle with the bleach. I had to look a little to find it, but it was there.
/ Electrolytic Rust Removal #29
and bicarb can cause metal pitting....
/ Electrolytic Rust Removal #30
Homemade Washing Soda
Soda ash is the active ingredient in washing soda. The chemical name for it is sodium carbonate, chemical formula Na2CO3. It is more basic, that is, less acidic, than sodium bicarbonate (baking soda), whose chemical formula is NaHCO3. The purpose of sodium carbonate is simply to increase pH.
Hydration
Some forms of soda ash (e.g. that labeled as 'washing soda') contain more water molecules than others, which makes them weigh more and be larger for a given number of sodium carbonate molecules - this means that you need to measure out a larger quantity of the hydrated form in order to get the same results. If you buy sodium carbonate without the extra water molecules, then store it for several years in humid conditions, it will absorb some water and appear to lose strength, when in fact it has merely 'bulked up' and needs to be used in larger volumes.
The type of sodium carbonate used in washing soda is a decahydrate, so you need to use a lot more washing soda than you would anhydrous soda ash, perhaps three times as much - assuming that you are able to find pure unadulterated washing soda that is suitable for use in dyeing. (In theory, we should use 2.7 times as much washing soda as a substitute for soda ash, if measuring by weight, or 4.6 times as much if measuring by volume.)
Where can you buy soda ash?
Although you can buy washing soda in the grocery store, this is usually advised against, because some US brands in the past were known to contain optical brighteners, salt, and/or fragrances. However, Arm & Hammer brand "Super Washing Soda" does not now contain any additives, though you must use a larger quantrity due to its greater hydration level (see above). A better source is a swimming pool supplies store, or a hardware store that carries some pool supplies, which will carry pure sodium carbonate (a popular brand is pH Up), sold for the purpose of increasing the pH of pool water. This is typically cheaper than mail-ordering from a dye supplier, and just as good. Beware of suppliers that try to sell you sodium bicarbonate instead of sodium carbonate; bicarbonate is much less basic (it has a lower pH), and will not work for most dyeing recipes.
/ Electrolytic Rust Removal #31
I've done this a few times myself, I've used the welder for a big ole jack screw I got for next to nothing at an auction that was rusted up and a 3 point top link that was rusted together. the bat charger worked pretty good but took a while the welder was a couple hours and yes water got hot and the jack screw got clean! I used the arm&hammer washing soda not bi-carbonate used "sodium carbonate." It was done vertically in a 6" PVC pipe stood it up and sealed the end. I used some wire mesh 2" that I rolled up and slid into the 6" PVC it sprang out against the inside edge of the PVC the jack-screw was suspended from a heavy wire.
Sorry no pics results were good, now I have a sandblaster and big compressor so the little things are easier & quicker & probably less energy using sand. the electrolytic ver is great to have for items that are more fragile than sandblaster can do thou...
Mark m
Here's my update. I fabricated a nice electrode to put in the middle of the kettle. See the first picture. I suspended that plate in the middle of the kettle and connected the center anode together with the anode on the side of the bucket using a copper wire. I left this for a day (~12 hrs). There was lots of bubbling and a lot of scum on the top of the water. The second picture shows the results. The outside was pretty much clean this morning, but it improved slightly over the day. The inside has improved, but I'm going to leave it for a few more days.
If I were in a hurry I'd probably pull the kettle out tonight, season it, and use it just like it is. I have plenty of time, though, and I'm curious to see just how much I can do with this technique. One thing I've noticed is that there are a few spots of built up hard water scale on the inside of the kettle. The hard water scale doesn't seem to be as affected by the electrolysis.
Questions: What is the proper ratio of washing soda to water? How do I know if I have enough? Would more washing soda make a better result? What happens if I have too much? For reference I used 1/2 cup for about 4 gallons of water.
/ Electrolytic Rust Removal #33
Hey IPlayFarmer:
Looking pretty good, I think your solution might be a little light on the washing soda I usually run mine about a heavy cup in a 5 gallon bucket with water down a bit from the top w parts in it. Also you dont have to keep electrode all way around outside if it is clean already put it back in add some more soda and use the center electrode only.
the electrolysis wont affect the lime/scale, perhaps tossing in some CLR or Lime-a-way prior to re-treating it in the bucket that should knock off the lime/scale and help get to the rust faster. Other would be use some Muratic Acid (not straight) to knocks off the lime/scale first...
GL Mark
/ Electrolytic Rust Removal #34
more soda makes for more conductance. won't hurt.. may not be needed if you can already go to max scale on your charger.
after cooking nother day.. use clr on her.
after that I'd boil her in a stock potwith regualr soapy water for quite a while..
I was trained in the old school of cast iron care where soap is strictly forbidden. The legend is that soap will get into the pores of the metal and flavor your food. Will the soap flavor not come through in the water? I expect to use this kettle to boil water for hot chocolate, etc.
/ Electrolytic Rust Removal #36
most soaps are bases.. just like that stuff you are cooking her in right now!
/ Electrolytic Rust Removal #38
Only soap mom ever used in her's were Lard Based homemade Lye soap. I use DAWN to degrease mine and rinse well then spray in some PAM if I dont have some bacon grease handy. Usually only done when something has stuck (not very often but sausage crumbling to make gravy does stick.) Surface gets bits of sausage burned to it as I like to brown mine well prior to making gravy in the pan.
Best seasoning is half full pan of good canola oil and some chicken or pork cracklings getting cooked in it. even if you dont eat the cracklings this will pull in the grease (into the cast's pours) as pan is well heated and oil has some pressure to help it move thru towards the heat. For your pot I would get some good cleaning and soak it in HOT SOAPY water to clean out the de-rusting soaps then bake it in the oven un-treated for 20 min at 300+F empty then let it cool, get some canola and roll it all around inside and outside, re-bake it for a bit and spray inside with Canola spray & bake again...
MM
/ Electrolytic Rust Removal #39
yep.. deffinately what I would do.. get all the contaminantes out.. then bake and treat.
i wouldn't want to taste electrolysis leavings in my first glass of tea.. :)
Based on the recommendations here, I washed out the kettle and seasoned it. I did three very light coatings of oil followed by an hour in a 350 degree oven after each coat. I let the kettle cool between coats.
I also started the second kettle in the electrolysis. This second kettle is in much better shape, and I look forward to even better results. I'll likely leave this second kettle in until Saturday. I won't have time to do much with it between now and then other than scrape off the electrodes and maybe wipe the residue off the kettle occasionally.
UNUSED KJ 33'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 33'X25'...
2006 Honda Accord Passenger Car, VIN # 1HGCM663X6A039043 (A61165)
2006 Honda Accord...
2014 Ford F-550 4x4 Service Truck with Crane, VIN # 1FDUF5HY9EEB69513 (A61165)
2014 Ford F-550...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
JOHN DEERE 344H WHEEL LOADER (A63276)
JOHN DEERE 344H...
(4) Tex Star 205/75D/15 Tires and Rims (A64047)
(4) Tex Star...
