Backhoe John Deere 310 3cyl drivability issue
/ John Deere 310 3cyl drivability issue #1
Villagebarn
Fleetwood pa
John Deere
Hello everyone, John here... I just picked up a jd 310 because as the fellow went into a pile, it just stopped moving..... No fwd or rev.... 3 cyl runs well, and all works well.... Anyone have any ideas?... I got it delivered last night .... I used the diff lock to eliminate a broken axle... Thank you
/ John Deere 310 3cyl drivability issue #2
Might wan't to clarify whether this is the ag tractor or backhoe/loader you have.
/ John Deere 310 3cyl drivability issue #3
How about a broken clutch disc? Try changing gears with the engine running without stepping on the clutch. If you can shift probably bad clutch.
I can't believe it!!! I picked up this 310 backhoe for 2500 because it didn't move ... Engine runs and hyd strong,... No fwd or rev.... I checked fluid and crawled under... It was a cotter pin missing from the linkage bar that goes into or near what I believe to be called the reverser.... Thank you everyone for your input!,,,
John
/ John Deere 310 3cyl drivability issue #5
John
Awesome deal. Gotta love it. I have a 310A. Rebuilt the injector pump last year. Good machine but could use more hyd power. I guess I could adjust the valves?
2000 KENWORTH T800 CRANE TRUCK (A67714)
2000 KENWORTH T800...
backhoe
backhoe
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
Bomag Roller (A63689)
70" Padfoot Shell Kit (A68134)
70" Padfoot Shell...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
