Trash & Treasures + What is it's
/ Trash & Treasures + What is it's #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
View attachment 283756View attachment 283757I'm starting to rescue some old & antique tools & misc other things from my Grandfathers place.
These few little items are just the start. Some quite useful and others 1 step up from junk.
Most of the I know the use of and the names. But there are some I don't have the name or real use.
The real hang up for me is the chain wrench. Use & Name??? 1 Funny looking little wrench I use fairly often, but do not know what it's name is. The long saw I have always called a "Whip Saw". Real name??? Whip Saw, because it had a tendency to sing & vibrate while in use?? Or because it whipped your butt by the end of the day??
Have fun I'm going to let you folks name all of them if you can.
The old anvil was made in England, it has had a hard life. It's in the 100# range but much of the writing has been messed up.
I tried to delete the Tarantula pictures, there was no way that I could do it. :confused3:
/ Trash & Treasures + What is it's #2
That's one big brown hairy spider! Glad you kept those pics in the mix.
The cain wrench looks like it would be just the ticket for threading togeter large plubing bits.
For another interpretation of what the long saw is good for (at around the 2:00 mark):
"Ain't No More Cane" - YouTube
Compliments to Poor Old Shine, our local group that is getting lots of time on the local stations and music halls.
/ Trash & Treasures + What is it's #3
/ Trash & Treasures + What is it's #4
Jim Looks like my tractor shed Only the tools are used not rusty. #3 pic looks like a dog.
Last pic seem to be some ones leg.also have spiders in the shed keeps the bugs rolled up.
The chain wrench used in plumbing or keeping a pipe from spining while using a threading tool
The locks are they labeled as Rail road . or Pwr. co.?
Best location is on a wall high enough so cannot easily removed.
Some day wil become antique then saleable.
Rethinking of the Ariz. trip will be next spring and have couple of tools you will need to add to your collection.
So save some space.
ken
/ Trash & Treasures + What is it's #5
Top right I see a Cant hook, for rolloing logs. A miners pick, use in coal mining years ago, and a pick/Mattock.
Somewhere down lower, the adjustable wrenches, some called them "Monkey Wrenches". Was your Grandfather a Railroader..?? Those look like switch locks.
/ Trash & Treasures + What is it's #6
The two after the spider look like wood working tools. I'm thinking the small one is used for removing bark from logs by straddling them and pulling it towards you. I think the other one is for shaping logs for building. I could be wrong.
/ Trash & Treasures + What is it's #7
And lots of one man cross cuts...!!
My dogs love to help (?) and are quite curious about anything different. Partly hidden by the dog is what I think is a R/R spike driver.
In between the 2 draw knives is something that I don't have clue as to what it is or real use.
The pick in the picture is about 1/2 the size of most picks. Use?? Coal mining?? or tight space in any mine??
The alligator looking wrench works pretty much like a ratchet and I use fairly often. Think that the came in several sizes. This on fits nuts from about 1 inch down.
The hand drill is really old, but the cast handle is not original and has been brazed on.
In pic #5 is a large soldering iron. At one time there was a burner used to keep it hot. There are also 2 old wood stove legs.
Does the chain wrench have a real name?? "Cain Wrench"??
There are 4 monkey wrenches, I think that was the only name they ever had. Below them are 2 "Ford" style wrenches. I say "ford" style as neither was made or stamped Ford. Similar wrench came with a new Model "T".
The 2 big "S" shaped open end wrenches were for use on large horse drawn wagons. They appear to be hand forged. hard to see are also 2 wagon axle nut wrenches.
The little saw blade in the picture is for a "Buck Saw". I plan to build it some new handles & tension-er.
Is "Whip Saw" the correct name for the big saw. I don't think it was a "Felling" saw, it's a little short. I have another a whole lot longer & heavier.
Peavy""" I should know witch tool that is. But the brain cell died. :laughing:
The tarantula was pretty large about 4 inches across. They are fairly tame and have no fear. Didn't bother him when the dogs sniffed him. I put my hand down to see if he would crawl on it. But he just took his time turning and slowly walking away.
/ Trash & Treasures + What is it's #9
I've always known it as a chain wrench -- my father had one we used on stubborn pipes in boilers -- they were made to be pipe wrenches but were useful in any number of ways where you need to turn something with leverage -- I still have Dads and use it frequently.
The peavey (log roller) with the hinged hook is not missing its spike -- it is the small bump on the iron collar on the end.
I think the pick axe is a miners pick -- used as you speculate in tight spaces
/ Trash & Treasures + What is it's #11
Oh, and above the picks looks to be a railroad hammer, the long head would help you drive the spikes without busting the handle on the rail...?
/ Trash & Treasures + What is it's #12
Link to an 1896 tool catalog is below. Click on the tool name, then scroll to the bottom of the page for the old tool catalog page.
Old Woodworking Tools-Old Wood Working Tools - 1897
The picture after the spider is a ball-peen hammer, two draw knives, and an adze head.
Bruce
Thanks to all for the information.
The old "Treasures" rescued this time were mostly out side hanging on the outside of the black smith shop.
Inside, when I get a lot of junk & trash cleared away are some good things.
Hand cranked drill press that I used a few years ago to drill some steel with.
Timber framing Drill -Complete set of pipe dies & handle - Several odd ball pipe threading handles & some dies to match.
If someone knows the name of the little ratchet wrench in the picture please let me know. Thanks Pictures are the old building that I will be cleaning out and hopefully building some similar here.
There should a lot of other old and useable tools, for forging. wood working & wagon related.
/ Trash & Treasures + What is it's #14
My mistake -- you are right -- it is a cant hook not a peavey - I have both and have always used the cant hook -- I find the peavey to be a PITA:eek: --
/ Trash & Treasures + What is it's #15
That is an adze head. Kind of like a "sideways" axe, but has a slight curve, and the bevel is on the side toward you when in use. Used (for example) to flatten rough planks, or make a flat edge on logs.
/ Trash & Treasures + What is it's #16
Some timbers in our barn shaped with hand tools.
/ Trash & Treasures + What is it's #17
The anvil is a Peter Wright. English. Are there any numbers on it, should be 3 numbers.
The anvil is marked in English Hundred weight measurement.
Bill
/ Trash & Treasures + What is it's #18
Just to get technical (like the peavey comment):D a pick with one pointed end and a flat blade on the other (as in your pictures) is called a matlock. The wrench is called a double alligator wrench.
Thank You.
I do have an adze and its in pretty good shape.
What is the pin for on the Matlock???
/ Trash & Treasures + What is it's #20
I think it's a "maddock". (Maybe another name for matlock?) I've also heard them called bog hoes. We used them for digging trenches.
