Buried baling twine... In a grid pattern!
/ Buried baling twine... In a grid pattern! #21
I'm thinking round bales ... twine tied. Is it an area where someone may have been feeding livestock and not removing the twine? When I bought this place 8 years ago the old boy had been feeding round bales in a lot and never removed the twine ... I still find them in that area.
A round baler has continuos twine when the baler starts the tie cycle ... that could explain the long pieces.
/ Buried baling twine... In a grid pattern! #23
Sounds like a landscape rake could do the trick if you have more left...
Aaron Z
/ Buried baling twine... In a grid pattern! #24
This sounds the most plausible to me. I'm hoping that we have fixed the problem; I'll be out there working on it this weekend, cleaning up / leveling / getting rid of Johnson grass. I find it odd that it has been in this condition for what appears to be at least a few years, when it took us less than a week altogether to clean it up. People can be funny at times :confused2:
/ Buried baling twine... In a grid pattern! #27
I bought a "lazy farmers" farm. You would be surprised how long it takes to fix all the problems. Ruts from logging, steel posts in the the middle of the field, even a whole cedar log right in the middle of grown up pasture. The plastic baling twine will take a century to get rid of!
I agree it sounds like round bales, although the 1" grid is still baffling. I think I doubled the size of my fields just lambing and cleaning up the edges. Have fun!
We must be neighbors - our back fence line is the county line between Lawrence and Giles counties.
/ Buried baling twine... In a grid pattern! #29
I ran into the twine problem a few days ago in an area I had set up for one of my mini-horses to graze while I worked on his pasture. It sounds like a similiar problem with what looked like red "shoots" interspersed throughout a 20X20 area. I've owned this for 5 years, and it was the first time I noticed it. I moved the temp panels and just started pulling it up. I have a Ratch rake, but the grass looks good in the area, so I didn't want to tear it up any worse than I had to.
From some of the other items I have found here, I'm sure it was a a small area the former owner set up using short metal posts (almost like rebar) and some type of electrical wired fence ( my mower used to "find" that all the time). If that's the case, I vote for hay bales put down still wrapped.
/ Buried baling twine... In a grid pattern! #30
Sounds like it could be an erosion control mat placed down prior to planting to hold the grass.
/ Buried baling twine... In a grid pattern! #31
/ Buried baling twine... In a grid pattern! #32
Wow, Pulaski and Summertown folks. TBN is getting close. Hey guys I guess I am a neighbor too. I am in Lawrence Co. about 8mi out of Summertown toward Henryville. I am going to vote for a round bale feeding area as far as the twine grid goes. There could of even been a round bale unroller in use.
The square foot garden bed picture that bcp posted reminds me of a tobacco plant bed which would be common around here but I can't associate the twine grid to it.
/ Buried baling twine... In a grid pattern! #33
OP, we are pretty close for Internet "neighbors". I'm in Giles but over near I65.
I'm still baffled on the grid pattern. Any chance you could post a picture of it?
I spent the evening trying to reclaim about a half acre grown up in locust trees. Using the chain saw because the darn things don't push out well with the fel. I still have 20 or so to go.
Sorry, the only pic that I could provide would be one showing a pile of baling twine ready to be bagged up. If I come across any more buried twine I'll take a pic and post it.
/ Buried baling twine... In a grid pattern! #35
GPintheMitten said:
Aliens did it.
My thoughts exactly. Could be related to crop circles.
Possibly they kept moving the bale feeder which would explain the large area.
/ Buried baling twine... In a grid pattern! #36
it is where roll hay was fed.let frost kill the johnson grass ,then burn it off.that will get rid of most of it on top of the ground.
/ Buried baling twine... In a grid pattern! #37
Ok .... were there ever greenhouses set up there? Could these be some of the strings used to tie up cucumber plants or something along those lines?
/ Buried baling twine... In a grid pattern! #38
Would it help get the last of it removed, by going over the area with a deep ripper or the rippers on a box blade?
I saw something similar once. The demolition contractor on a school replacement used a deep ripper to tear sprinkler pipe out of the huge lawns. This worked great - until he ripped out a pressurized undocumented water main that came into the campus from the street. That ripped a hole in the big water main in the street. Huge mess! :) Your story reminded me of seeing that.
