Buried baling twine... In a grid pattern!
   / Buried baling twine... In a grid pattern! #21
I'm thinking round bales ... twine tied. Is it an area where someone may have been feeding livestock and not removing the twine? When I bought this place 8 years ago the old boy had been feeding round bales in a lot and never removed the twine ... I still find them in that area.
A round baler has continuos twine when the baler starts the tie cycle ... that could explain the long pieces.
   / Buried baling twine... In a grid pattern! #23
Sounds like a landscape rake could do the trick if you have more left...
Aaron Z
   / Buried baling twine... In a grid pattern! #24
This sounds the most plausible to me. I'm hoping that we have fixed the problem; I'll be out there working on it this weekend, cleaning up / leveling / getting rid of Johnson grass. I find it odd that it has been in this condition for what appears to be at least a few years, when it took us less than a week altogether to clean it up. People can be funny at times :confused2:
   / Buried baling twine... In a grid pattern! #27
I bought a "lazy farmers" farm. You would be surprised how long it takes to fix all the problems. Ruts from logging, steel posts in the the middle of the field, even a whole cedar log right in the middle of grown up pasture. The plastic baling twine will take a century to get rid of!
I agree it sounds like round bales, although the 1" grid is still baffling. I think I doubled the size of my fields just lambing and cleaning up the edges. Have fun!
We must be neighbors - our back fence line is the county line between Lawrence and Giles counties.
   / Buried baling twine... In a grid pattern! #29
I ran into the twine problem a few days ago in an area I had set up for one of my mini-horses to graze while I worked on his pasture. It sounds like a similiar problem with what looked like red "shoots" interspersed throughout a 20X20 area. I've owned this for 5 years, and it was the first time I noticed it. I moved the temp panels and just started pulling it up. I have a Ratch rake, but the grass looks good in the area, so I didn't want to tear it up any worse than I had to.
From some of the other items I have found here, I'm sure it was a a small area the former owner set up using short metal posts (almost like rebar) and some type of electrical wired fence ( my mower used to "find" that all the time). If that's the case, I vote for hay bales put down still wrapped.
   / Buried baling twine... In a grid pattern! #30
Sounds like it could be an erosion control mat placed down prior to planting to hold the grass.
HYD AUGER W/ 10" BIT (A52708)
HYD AUGER W/ 10"...
Kubota M108S (A53317)
2020 DRAGON ESP...
SET OF TRUCK FENDERS AND HARDWARE (A58374)
SET OF TRUCK...
TANK MANIFOLD (A55745)
HOMEMADE STRIPE BOAT (A52708)
HOMEMADE STRIPE...
