mvwicker
Gold Member
There is an 8x8 ft deck about 10 feet above ground, supported by two trees and two 4x4 in legs, on a hillside above a meadow in the middle of my property. In the past I cobbled a hunting blind atop it out of ropes and a tarp, but it really needs a roof and sides and a gunrest and a shooting window (and a carpet and some comfy chairs and a coffee maker and a flatscreen TV and ...
). The first step was to replace the original 4"x4"x10' front legs, which were flush with the floor, with 4x4x16' legs that could support a roof.
Here is the original setup, before this project:
http://www.tractorbynet.com/forums/...39d1349063932-enhancing-tree-platform-002.jpg
The tractor served as a lumber hauler, tool carrier, and temporary jack. I put the 4x4x16' posts along one side of the tractor, supported in front by the FEL bucket and in back by a pipe clamped to the ROPS. This idea came from TBN. Shorter pieces of lumber to be used later were tied to the long 4x4s. The FEL bucket carried all my tools and fasteners:
http://www.tractorbynet.com/forums/...40d1349064248-enhancing-tree-platform-003.jpg
Next I parked the tractor under the platform to use the FEL as a temporary support. I chocked the wheels with large rocks (plentiful on my property!) and lowered the box blade for extra stability:
http://www.tractorbynet.com/forums/...41d1349064504-enhancing-tree-platform-004.jpg
http://www.tractorbynet.com/forums/...42d1349064606-enhancing-tree-platform-005.jpg
http://www.tractorbynet.com/forums/...43d1349064893-enhancing-tree-platform-006.jpg
I used a water level made from a 2-liter soda bottle, 1-hole rubber cork, yardstick, rubber bands, food-colored water and 100 feet of polyethylene tubing. It is simple to use and completely reliable over long distances:
http://www.tractorbynet.com/forums/...44d1349065045-enhancing-tree-platform-007.jpg
http://www.tractorbynet.com/forums/...45d1349065172-enhancing-tree-platform-008.jpg
With the FEL holding up the platform, I removed one leg, replaced it with the longer post, drilled pilot holes and lag-screwed the new leg in place:
http://www.tractorbynet.com/forums/...46d1349065331-enhancing-tree-platform-009.jpg
http://www.tractorbynet.com/forums/...47d1349065549-enhancing-tree-platform-010.jpg
http://www.tractorbynet.com/forums/...48d1349065619-enhancing-tree-platform-012.jpg
Then I did the same to the other side:
http://www.tractorbynet.com/forums/...49d1349065752-enhancing-tree-platform-016.jpg
Here are the "After" photos, from the platform and from the ground:
http://www.tractorbynet.com/forums/...50d1349065839-enhancing-tree-platform-015.jpg
http://www.tractorbynet.com/forums/...51d1349065974-enhancing-tree-platform-017.jpg
http://www.tractorbynet.com/forums/...52d1349066049-enhancing-tree-platform-018.jpg
This was a good checkpoint, so I called it a day. These pictures don't show some of the more time-consuming steps like pulling the old posts out of the holes, which then had to be dug out or filled to get the new posts to the right depth. Also, the FEL lift and curl were both used to get fine height adjustments before the platform was attached to the new legs. At no time did I work under the loader, and the ladder always had a good brace to lean against.
The posts rise 6'2" above the platform which is high enough for me, but I may add a header before putting up the roof to make room for my taller friends.
