Broken Pin - BH77
/ Broken Pin - BH77 #1
Mac in PA
Somewhere North of the Mason Dixon Line
Kubota L 3800, Austin Western Pacer 100
Well it finally happened, the pin that holds the two cylinders on the boom broke Wednesday night.
I latched on to a rock in the ditch trying to pry it loose. I was working the bucket, boom and dipper at the same time, which had worked many times before to pry a rock loose. I heard a loud crack even over the roar of the engine at full throttle and ear protectors on. I then noticed that the boom cylinder and dipper cylinder were wiggling in two different directions at the anchor point. Checked it out and the pin had broken. Luckily there wasn't any weight in the bucket so it didn't damage the boom at the pin anchor holes.
The first picture shows the broken pin, which broke at the weak point, the grease groove. The second picture is the new pin. It may not be visible but it looked like the heat treating was different at the grease groove and 1/2 inch on either side of it. Improvement? ? ?:confused3:
Picture three is before the broken pin was removed. No evidence that it was broke. The last picture is with the new pin installed.
Before I assembled everything I pulled the cylinders back and made sure the new pin could be slid in place easily by hand. This verified that the pin anchors were not twisted or damaged.
I ordered the part Thursday from Messick's and asked them to get it UPS Next Day Air and I would pay the freight.
Warranty covered the cost of the part. Everything worked out as planned and I had the BH up and running the next day. :applause::applause::applause:
/ Broken Pin - BH77 #3
You could view it as a fuse failure...
At some point things are overstressed... it is good to have an affordable & easily replaceable part fail, before something major breaks.... KennyV
/ Broken Pin - BH77 #4
the pin was heattreated to hard thats why it snaped.
/ Broken Pin - BH77 #5
The only problem with that is that most of these I've seen bend the cylinders ears and the tabs on the boom with it.
Was this one of the early 'problem' pins or one after the recall? I've been thinking about a BH77 for my B3200 but this issue has worried me all along.
/ Broken Pin - BH77
Was that a 3/4" or 1" diameter pin?
The pin is 1.172" in diameter or a little over 1 1/8"
I bought the BH77 new January of this year. I was not notified of a recall if there was one for my unit.
I believe I was very lucky that I caught it before any major damage was done. I'm not sure what caused it to break but it looked like the pin was partially broken or cracked. There was a dark area on the one side of the break about 1/8" wide, which indicated to me that it was cracked for a while before breaking.
Mac
/ Broken Pin - BH77 #8
Mine broke the second time I used my BH. I was digging a pine stump out of sandy soil and SNAP. It mangled the ears on the dipper and the dealer replaced everything under warranty.
/ Broken Pin - BH77 #9
IMHO: The shared mounting point allowing the cylinders to apply force against each other is probably the problem. If this is a common problem on the backhoe the only relatively inexpensive "fix" would be to retro for a larger diameter pin.
/ Broken Pin - BH77
Replacing the pin with one that has no grease groove will probably fix the problem also. I don't believe that this groove is necessary.
Mac
/ Broken Pin - BH77 #11
Mac
Mac,
Glad to see that nothing else was damaged, including yourself!
Does anyone (besides me?) see the possibility of a broken pin as being a safety risk to the backhoe operator? I realize that the other ends of the cylinders remain connected, even if this pin breaks, but it's still kind of skeeves me--the possibility of flying chunks of steel, just a few feet in front of your face?
Does anyone know if the "Groundbreaker" series of Woods' backhoes also locate two cylinders on one pin?
I'm considering buying a machine from a private seller that already has the BH 77 on it. I'm not sure of the exact year of the machine, but it is older than your backhoe, Mac, so I wondered if anyone has any information on which serial numbers of the BH77's were affected?
Better yet, does anyone have a copy of the recall? Like Messick's, perhaps? And kudos to Messick's for taking care of you as well as they did.
Thanks all,
My Hoe
/ Broken Pin - BH77 #12
The current models of Woods' Groundbreaker hoes all share a pin between the boom
and dipper cylinders. Indeed you will find that curvy-boom hoes in general do this, from
most vendors. Older straight boom hoes do not.
This is an inherent limitation to this design, not just because of the greater bending
forces applied between wider-spaced supports. But also, lube is only applied
thru the zerk on the center section. The cylinder with the ears is not force-lubed.
On the hoes I have seen anyway.
IMO, to make this design work, you need 3 zerks and a pin size of at least 1.5"
diameter. And no grease groove!
/ Broken Pin - BH77 #13
dfkrug,
Thank you for the info on the current Woods' designs--and for your obseravations, generally.
Definitely food for thought.
Thanks again,
My Hoe
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
2016 John Deere Z535M Zero Turn (A63116)
2016 John Deere...
Chandler 9PT-FT High Clearance Fertilizer Spreader (A64047)
Chandler 9PT-FT...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59910)
2019 ISUZU NPR 4X2...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
