French Drain - River Rock or Crushed Stone
/ French Drain - River Rock or Crushed Stone #21
We use #57 gravel here, which is 3/4-1" size. We also line/wrap the trench with septic fabric to prevent the soil/clay from infiltrating into the stone. So the steps are:
1) dig trench
2) line with septic fabric
3) drop in about 2-3" of stone
4) place pipe with perforations on the bottom
5) cover with more stone up to about 6" below grade
6) fold over septic paper and roll the seam
7) cover with top soil to grade
/ French Drain - River Rock or Crushed Stone #22
I have heard of some people having french drains without the corrugated pipe.
/ French Drain - River Rock or Crushed Stone #23
Definitely. In fact, if the drain runs down a change in elevation in clay soil, you can skip pipe on the upper parts and only use it on the lower half.
Or if the base soil is sandy and drains well, the french drain can be all stone since it will just direct surface water down to the sand layer, and doesn't necessarily need to move it laterally.
/ French Drain - River Rock or Crushed Stone #24
This was part of a large drain project I did which might show what some others on have described. This was a high end job and worked out very well to protect this really long asphalt drive from future washout. The pipe is 4 inch smooth bore (about 220 feet installed in this part) which is semi flexible and also used schedule 40 to the catch basin, under the concrete trench drains across asphalt drive and across concrete pad up top of the one photo. About one foot of #2 limestone was used on top of the four inch wrap. #57 limestone was used inside the wrap.
/ French Drain - River Rock or Crushed Stone #25
Nice-and it looks like that the drain system you used across the road was one of the precast polymer types? what brand?
/ French Drain - River Rock or Crushed Stone #26
That looks very nice. I need one of those trench drains but I am not sure how to do it with a gravel driveway, I am afraid the plow will hit it in the winter.
/ French Drain - River Rock or Crushed Stone #27
We've got some with crush some with river rock. For us the river rock was about 1/5 the price of crush when its available. Both work equally well. The river rock is slightly easier to shovel but the tractor scooped both equally well.
/ French Drain - River Rock or Crushed Stone #28
The gutters around our house ended about 2' before the ground when we moved in. I extended the gutters, and put in solid pipe from the end of the gutter until the pipe was sloping away from the house.
(all 4''). Then I put in 2-3'' of stone and compacted it, then put the pipe in covered and compacted, and then added 2'' more of stone and compacted. covered and it has worked great. It carried water away from the house during the last few 100 year storm events we have had.
2013 HERCULES ALUMINUM KILL TRAILER (A60736)
2013 HERCULES...
Deere 333E (A60462)
Deere 333E (A60462)
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2017 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60352)
2017 Ford F-550...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
2011 CIRCLE M  35 GOOSENECK (A60736)
2011 CIRCLE M 35...
