Grounding Welding Table - ????
/ Grounding Welding Table - ???? #1
crash325
Elite Member
Tucson AZ
New Holland TC-45
I plan on putting several 110 Volt outlets on my welding table. Was thinking about using the table as a ground.
But since it is also the ground for the welder, there may be some kind of feed back into the 110V line and really screw things up.
Latest Idea - Isolate the table from the 110V LINE
Ground table to a real ground - As in mother earth.
Sure like to hear from some of you folks on the subject.
Thank You
/ Grounding Welding Table - ???? #2
I'm not seeing the point in earthing the table. You definitely should NOT tie the 110 outlets to the table. I've had some smokey experiences from unforseen ground loops and power supplies while working in the field.
I'm not seeing the point in earthing the table. - Just a thought - You definitely should NOT tie the 110 outlets to the table. I've had some smokey experiences from unforseen ground loops and power supplies while working in the field.
Thanks for your ideas - Had pretty much decided not the ground 110v to table.
/ Grounding Welding Table - ???? #4
Ditto
I wouldn't tie the table to the outlets. Seems like a shocking experience. We don't need the extra fires in the SW :fiery:
RC
/ Grounding Welding Table - ???? #5
Can't see any reason to tie the table to ground. You've got a ground clamp on the welder that does the job when it comes to welding. In fact, to optimize the welding process you need to place the ground clamp as near to the workpiece as you can (or better yet - ON the workpiece).
/ Grounding Welding Table - ???? #6
My 110 outlets used metal boxes and condut, they are grounded,and are connected to the table. Never had any problems running any tools or welding, I'd rather have it tied in to the table in case of short on the 110 side. Welding ground should have no affect on the 110 ground, though I always clamp as close to the weld as possible and rarely use the table itself as the ground point.
/ Grounding Welding Table - ???? #7
Using the table as a ground for any 110v circuit is asking for trouble. You might go for years with zero problems, but it will only take one time for a circuit to short to ground and you might be providing a path from one hand to the other, across your chest, and bingo, dead.
The short may not even occur right at the table, but anywhere in that circuit.
/ Grounding Welding Table - ???? #8
My inclination is to isolate the 110 outlets from the the welding table.
I just looked at Miller's Arcstation welding tables and they don't offer 120VAC outlets on them.
/ Grounding Welding Table - ???? #9
Ground is ground. What's the problem?
/ Grounding Welding Table - ???? #10
I have a surge protector with several outlets hanging off a screw on my table that way if something happens to the things plugged in it will throw.
/ Grounding Welding Table - ???? #11
The problem would be, for instance, if the table was grounded for line-voltage, but the welding machine was inadvertently not grounded to the table. Hit an arc, and the return current could melt the 110v boxes, ground, EMT, SO cord and everything to the panel.
/ Grounding Welding Table - ???? #12
Wow, I see we need work in general about electric here. If this table has any potential to be be energized it must be grounded to the electric system.
Back later.
/ Grounding Welding Table - ???? #13
There are some questions. If this is a stand alone bench with stand alone welding equipment there is no problem having 120, its done all the time. You are looking to avoid an alternate pathway for welding currents is correct but any metal object exposed to power needs to be grounded. Only exception a guy could make is to feed it from a gfci circuit. If its not grounded,, and this does NOT mean a ground rod it has the potential to become energized, say from a pinched wire from a tool cord, standing 120V, no fault return.
Put the work lead from the welder on the bench, not a problem. In my own case have a steel building, benched welded to the floor and bonded to building with a rod at which point have common work grounding for multiple welders. I faced thidilemmama at one point, equipment all over I finally made some changes but supply the bench with a wiree3 circuit preceded gfci, the bench IS grounded just not with a conductor from the electric circuit, 2 benches in this scheme but ieliminateded the possibility of ground wire from being used as conductor for welding current.
Main thing is not to get confused, ground rods are nevesubstitutetute for an equipment ground. Ramble, probably clear as mud, jump in without hurting my feelings, ha
/ Grounding Welding Table - ???? #14
Only if the welding ground was touching the buildings electrical ground!
If you have installed a 110v outlet it probably has a 3 wire grounded ( u ground) receptical . The ground in that receptical MUST have a continuous ground wire back to the panel box ( unless its done with metal conduit ).
Sure, you could wind up shorting out the ground conductor in a drill/ grinder cord, but you would notice the smoke and get it repaired. Without that ground you could have the HOT wire on the grinder short to the case and you would then be holding 110v in your hands with no advanced warning!
/ Grounding Welding Table - ???? #15
Seems to me a healthy fear of electricity has saved my life over the years and my accepted belief is that I only do things that are in the mainstream of common use. If I haven't seen it before or it looks the least bit questionable, I avoid it on the basis that if there is trouble i will be the one the bad things will happen to. Yeah, I missed out on the 1% that may have worked but I avoided the remaining balance of trouble. Just my two cents.
Here is how I have it figured out and plan to do things.
110v will be isolated from the metal table.
Metal table will be grounded to Ground, as to the earth. - Chances are this is not needed???
When I get too it. :D
/ Grounding Welding Table - ???? #17
Your welder is grounded to the electrical panel ground, isn't it?
If you're running 110 to your welding bench receptacles, you'd run the ground wire too, wouldn't you?
The 110 receptacles would be solidly mounted to the bench, metal to metal. Surely you wouldn't isolate them?
Like I said originally (and someone ridiculed me), ground is ground. By that I mean there should be no difference in potential to cause feedback loops if all the connections are good and the wiring is to code. Even if there are potential ground loops in the order of a few millivolts, if everything is grounded to a common ground, there should be no problem. It's not like you're building a sensitive audio system where ground loops could cause undesirable noise.
/ Grounding Welding Table - ???? #18
The "ground" of the welding side of the circuit is distinctly different that the ground of the line voltage circuit
No one ridiculed you, some disagreed with your analysis
/ Grounding Welding Table - ???? #19
Which is actually quite common in commercial and industrial shops, where the welding machines are grounded to the building steel, and the fab tables are grounded by jumpers to steel beams etc
/ Grounding Welding Table - ???? #20
Common sense will always prevail.
If you're using a drop cord with a drill, grinder, or whatever and working on your table there's no ground on the table. Works fine.
In manufacturing plants the machinery is like a giant welding table when they're being welded on for repairs and they are grounded. Works fine.
If you're mounting a receptacle on your table just make sure the receptacle itself is grounded. It won't hurt if you ground the table with the same wire that's grounding your receptacle and that's what I would do.
2013 RANCO BELLY DUMP (A67714)
2013 RANCO BELLY...
BOX OF " NO TILL" DISCS (A65054)
BOX OF " NO TILL"...
2016 CHEVEROLET CAPRICE POLICE VEHICLE (A66091)
2016 CHEVEROLET...
2017 Crane Carrier Co. G-S Products 23yd Dual Side-Load Refuse Garbage Truck (A66736)
2017 Crane Carrier...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
