3-Point Hitch 3pt lifting height?
/ 3pt lifting height? #1
Woody65
Gold Member
East Northport and Oneonta NY
John Deere 4300 HST 4wd
I am new to operating tractors but have been having a ball the last month settling in to my new to me JD4300. When I lift an implement ( BH or finish mower) on the 3pt, I notice that it only comes up off the ground 5-10 inches. Is this normal or do I have the top link adjusted wrong. I have seen pics and videos of tractors with these implements at a 30 degree angle ( 20-30 inches) from the ground. Are they using a hyd top link to get the implement that high? Thanks :drink:
/ 3pt lifting height? #2
Your lifted height is set by the top link the shorter it is the higher your implement will travel when you raise your 3ph.
A hydraulic top link would be handy if you needed the clearance traveling then it could be leveled out before/or during use.
/ 3pt lifting height? #3
If you shorten the toplink it will come up higher. You may want to read your owners manual to be sure you have it adjusted properly for the mower.
When I hooked up to the BH, I connected the lower arems first and had to adjust the top link out 2 inches to make the connection. Are you saying that after hooking up I should then adjust it back in to allow for a higher clearance when lifting?
/ 3pt lifting height? #5
If you need the higher clearance then yes shorten it.
/ 3pt lifting height? #6
On my Kubota, at the tractor end there at TWO positions/pins where the Top Link may be connected, one above the other.
The top position/pin is the "normal" connection position for tractor end of the Top Link for most implements.
Lower position give much increased lift. I use the LOWER POSITION for my King Kutter 48" rotary mower. It lifts high.
Using the top/normal pin KK 48" RM only lifts about 10"
I have seen four positions, stacked, for the tractor end of Top Lift on big Ag Tractors.
( I also need the lower pin position to lift my Rollover Box Blade high enough.)
/ 3pt lifting height? #7
How high will the lift arms themselves raise? If you feel they are not raising as high as your owner's manual states they should, I would check your hydraulic fluid level.
/ 3pt lifting height? #8
most tractors have a max 2ft lifting hight depending on what implement your using at the time.shredders wont be to far off the ground no matter how your toplink is adjusted.
/ 3pt lifting height? #9
That height (5-10") sounds about right for my tractor with the brush hog on and top link adjusted to allow some float. Maybe closer to 10-12". There are a lot of different ways to alter this geometry, so spend some time looking at all the different pin/hole combinations there are on your machine. Also, read your manual and do some searches on this site for more adjustment ideas.
/ 3pt lifting height? #10
Check your lower lift arms also, some have two holes to adjust height v lift power/leverage.
/ 3pt lifting height? #11
I am surprised no one has cautioned about the adjustment for clearance when lifted versus when mowing. On my tractor when the top link is adjusted correctly for mowing allowing it to float the rear wheel will barely come off the ground when I raise the 3pt hitch. I do have a hydraulic top link which makes it easy to shorten if I need to lift the mower higher for transport. Shortening the top link will allow you to raise the implement higher but this may not be the correct adjustment when using the implement, just keep that in mind. Also remember the higher the implement is the higher your center of gravity is. Then conversely a big mower hanging low off the back could make the front end light. It is all a balancing act. Have fun with the new toy and pay close attention to how things feel when driving in order to stay out of trouble.
Sorry for the delay in responding. My son got married and had to tend to my fatherly duties. :DThanks for all the helpful responses. I will take them all into account the next time I get up to the property and get out on the tractor.:drink:I spent my first extended time in the seat repairing an old logging road with 40 tons of gravel. Found out I could really use a box blade or a rear blade but had a lot of fun and gained needed experience on the tractor and loader.
/ 3pt lifting height? #13
Check out tripler's suggestion. I had the same problem with my new Massey. I couldn't lift my 7ft finish mower high enough for the rear wheels to clear the ground for transport. On my dealers advice I went the second set of holes and picked up about 12" of height. To change blades I have to shorten the top link all the way so I can crawl underneath.
/ 3pt lifting height? #15
/ 3pt lifting height? #16
Easier to just drop the front wheels in a ditch or down over a step !
No, the point is please don't rely on the hydraulics to hold a massive weight up while you crawl underneath it. The neighbor kid crawls on your tractor while you are laying under there and kicks the lever by accident (or any other unforeseen problem). It's not the weight or accessability, it's the safety.
/ 3pt lifting height? #17
We always put jack stands to support our cutters when working under them and lower it on to them with no weight being supported by the 3PH.
/ 3pt lifting height? #18
Just say no to cinderblocks.
I will try that next time I get on the tractor. Thanks
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
(APPROX. 20) WOOD VEGETABLE BINS (A64276)
(APPROX. 20) WOOD...
HYDRO TEK PRESSURE WASHER (A65643)
HYDRO TEK PRESSURE...
2010 GREAT DANE SUP-1114-11053 53X102 REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
